05-19-2019, 12:50 PM | #1 |
11
Rep 69
Default driving settings without M1/M2 buttons
Is there any way to reset all the driving settings (i.e. dampers, gear change, steering weight etc.) to the default settings that are selected when the car is first started without using the M1 or M2 buttons?
I currently have M2 button set to the sportiest settings and and M1 set to D/efficiency/comfort/comfort but I'd really prefer to be able to use the M1 button for something else. |
05-19-2019, 06:21 PM | #3 |
5721
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
No. The car starts in the lowest settings on purpose. Mainly because it allows the car's fluids to all warm before you have it in the hardest settings and abuse the engine.
05-20-2019, 05:55 AM | #4 |
239
Rep 473
Pressing M2 again should return all the settings back to normal. At least that's what it does on my car - you press it once to activate (unless you have MDM on or DSC off, then you need to press twice to confirm) and press again to deactivate, which resets everything to comfort.
Snapper Rocks Blue on Tartufo leather | All options except Homelink and tow hitch
94jedi830.00 |
05-20-2019, 01:13 PM | #5 | |
11
Rep 69
What I meant was that I would like, while I am driving, to be able to turn all the settings back to what they were when I start the car. If I have changed all the settings (e.g. by using the M1 or M2 button that I have programmed in advance) I want to be able to go back to the defaults without stopping the car and starting it again. |
05-20-2019, 06:47 PM | #6 | |
830
Rep 1,254
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
05-21-2019, 04:47 AM | #7 |
60358
Rep 19,622
i just have M1 in easy mode and M2 in sprightly form and HUD rev counter comes on,in M1 hit it twice and rev counter comes on for that, just read the hand book.
05-21-2019, 11:26 AM | #8 | |
11
Rep 69
Thank you all for your help. |
