05-16-2019, 11:29 AM | #1 |
33
Rep 135
Drives: 2015 BMW M4
Torque specs for AA mid pipe install?
PLanning to install my AA mid pipe this weekend. I have new copper nuts and new gaskets, just in case.
Does anyone know the TQ secs for all of the bolts? Also, do I even need new gaskets? I got the two donut gaskets, but not the metal one. Thanks! |
05-16-2019, 01:36 PM | #2 |
2078
Rep 1,780
I've got mine waiting to install also and from what I've seen it's best to replace all the gaskets.
05-16-2019, 02:25 PM | #3 |
33
Rep 135
Drives: 2015 BMW M4
05-16-2019, 03:12 PM | #4 | |
2516
Rep 2,079
The donut ones you do need. Don’t worry about the torque specs much. See that the donut gaskets are properly squeezed. You’ll see it when you’re down there This should give you a visual |
05-16-2019, 03:15 PM | #5 | |
33
Rep 135
Drives: 2015 BMW M4
Thanks for the input. Love the videos btw! |
05-16-2019, 03:17 PM | #6 | ||
2516
Rep 2,079
Get under there the night before and soak them in wb40 or other rust removers. Get small metal drill bits just in case. |
05-18-2019, 04:36 PM | #7 |
33
Rep 135
Drives: 2015 BMW M4
Ok guys, even tho I sprayed the bolts down the night before with pb blaster, I was unable to get them lose.
What size are the nuts? I tried 11mm, and it seemed to fit, but spun when trying to remove them. I was able to hammer on a 10 mm, but again it just started to strip when I tried to remove them. They are definitely rusted solid. Not really sure what I can try next short of drilling them out. |
05-18-2019, 06:24 PM | #8 |
20
Rep 53
Hey mate,
Best thing to do is get a blow torch of whatever kind, those decent hand held ones will do the trick. Heat the bolt right up, the difference in expansion rate between the bolt and the pipe will crack it lose. Old trick that very rarely fails. Regards |
05-18-2019, 06:49 PM | #9 | |
2078
Rep 1,780
05-19-2019, 06:43 PM | #11 |
33
Rep 135
Drives: 2015 BMW M4
Thanks everyone.
I'll try some heat and an impact. Does anyone know what mm socket to use? It's definitely not a 13mm like the instructions say. |
05-20-2019, 02:19 PM | #12 |
33
Rep 135
Drives: 2015 BMW M4
Heres a photo of the bolts.
I'm thinking about getting a torch, heating them up, then using a impact wrench. https://photos.app.goo.gl/cg5pXKQsGDjpX6pk9 |
shellman091119.00 |
07-27-2021, 12:20 PM | #13 | |
882
Rep 1,044
Drives: 2018 M4 Competition
Tommy L's video above highlights having to deal with this.
Instagram: Slaughter.Mode
07-28-2021, 11:28 AM | #14 |
1836
Rep 4,203
Soak them in PB blaster/Krol oil then heat them with a heat gun good and hot. Then with a long extension and 10mm 6pt socket tap it on the nut. That will shave the rust off. Then ease it loose with a small socket. If you are too aggressive you will snap the bolt
05-22-2023, 05:25 PM | #15 |
Rep 2
This is a bit out dated post but I'm getting my AA EL tomorrow and preparing myself and came across this post.
Exhaust system to catalytic converter M8 Nut 19 Nm x4 Exhaust system to rear axle carrier M8 Replace nut 19 Nm x2 + x1 Exhaust system on transmission cross-member M8x25 Replace screw 28 Nm x2 Reinforcement strut to body, middle M8 24 Nm x6 |
