BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      08-05-2008, 05:35 PM   #1
BIGNTASTIE
BIGNTASTIE's Avatar
35
Drives: white/red 08 M3, 05 Rangerover
sports tires and snow
Is changing tires for the winter that important? I got the 19inch with sports tire options. Do i really need to change the tires for the winter?? thanks
      08-05-2008, 05:38 PM   #2
J08M3
J08M3's Avatar
Drives: 2011 M3 COUPE
In Queens NY I wouldn't bother worrying about it. We barely get any snow, and if it happens to snow one day just leave it home. It'll be melted the next day.
      08-05-2008, 05:39 PM   #3
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
Do you wear flip-flops in the winter?
      08-05-2008, 05:40 PM   #4
J08M3
J08M3's Avatar
unlike your feet I'm pretty sure the tires don't care if it's cold out.
      08-05-2008, 05:40 PM   #5
cncmastr
cncmastr's Avatar
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2006 BMW M3  [10.00]
While that may be true about the snow, you are completely ignoring the fact the summer tires are not designed and made for cold/freezing temperatures. The compound becomes as hard as a hockey puck in freezing temps and will loose traction.
      08-05-2008, 05:43 PM   #6
J08M3
J08M3's Avatar
issue on the track yes. but not on the street. and it's never really too cold for a long time in that part of NY
      08-05-2008, 05:43 PM   #7
BIGNTASTIE
BIGNTASTIE's Avatar
35
thats what I'm wondering, how much does temperature effect these tires?
      08-05-2008, 05:46 PM   #8
J08M3
J08M3's Avatar
I'd imagine it would be a great lawsuit against BMW if they sold you stock tires that would slide off the road as soon as it gets to freezing temperatures. Of course the traction goes down with colder temps, but like I said unless you're on the track it's not an issue.
      08-05-2008, 06:14 PM   #9
enfield
Civilian
enfield's Avatar
79
Drives: Jaguar F-Type V8 S
All-season tires become hard and loose grip below 7C.
Summer sports tires are even worse. It says on the sidewall what sort of tires they are. J08M3 - If it says summer then BMW is off the hook.
The issue is not just snow. Winter tires are called winter tires because the rubber compound and tread are made for rain, ice, and snow at temperatures down to -15 to -20C. Winter tires are superior even when the temperature is 5C. Once the temperature starts going above 10C winter tires start to wear out quickly because the tires are soft.
You have an expensive car and I know you can afford winter tires. Just get them and use them. It is a pain storing a set of rims and tires but do it. Get 18 inch rims and use winter tires. They will drop your stopping distances in the winter and stop you from rear-ending me!!
      08-05-2008, 07:45 PM   #10
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
You're in Ontario. It's different there. I used winter tires when I was in Minnesota; the temperatures made them definitely worth it. For someone in Brooklyn an argument can be easily made to keep the PS2s all year round. You really have to have constant temps near or below freezing to justify winter tires (or lots of snow, of course).
I would NOT put winters on if I was in Brooklyn. I've gone through two winters in New Jersey and Allentown. I did not need the winter tires there. Just remember, "No snow for you!".
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now.
Why, yes. I am an abrasive bastard.
      08-05-2008, 08:31 PM   #11
cncmastr
cncmastr's Avatar
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2006 BMW M3  [10.00]
They print on their brochures that summer tires are not intended for use in the snow. In Germany if you are caught with summer tires in an area with snow, they can fine you for creating a danger to others or something along those lines.
I disagree about tires not needing traction unless you're on a track. The difference between hitting someone could be 1ft. If my tires can't get the right grip because they weren't made for a certain climate than that is all the difference in the world.
And while it says I live in CA, I am from NY/NJ. I have done the cold weather thing there - that's partly why I left. I have gotten stuck on the road before with summer tires in the snow. And as for cold weather driving, you can def. tell the difference.
My advice to the original poster is go on tire rack or even buy a used set of 17" or 18" rims with Blizzaks on them. You save miles on the expensive summer tires while getting the best possible level of traction possible.
      08-05-2008, 08:33 PM   #12
cncmastr
cncmastr's Avatar
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2006 BMW M3  [10.00]
While I admit the analogy is open to interpretation, my point was that one wouldn't wear shoes that are not appropriate for the climate. If you go hiking you wear hiking shoes not high heals, etc.
      08-05-2008, 08:36 PM   #13
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
+10000! I had the M3 out in the cold with a bit of rain/sleet and it was LOOSE. A set of winter rubber seems like cheap insurance to me. Especially if you will drive the car daily in the cold months.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      08-05-2008, 08:38 PM   #14
J08M3
J08M3's Avatar
I never said you don't need traction. I just don't think it's necessary to change these tires in this region of the country for the different seasons. Of course you would benefit if you do, but I doubt it would be worth it for normal driving on the street.
      08-05-2008, 08:58 PM   #15
mkoesel
Moderator
Drives: No BMW for now
You've got plenty of evidence via google and indeed via this thread.
Only way to know for sure is to try it yourself. I've heard accounts from folks on E90Post who've done just that and can't get the car to move for shit.
Basically, a car in the winter without proper tires is a timebomb, in my mind. I'll allow that I'm being a bit dramatic here, but realistically, if you can't control the car then you are basically risking the lives of others because you decided to cheap out. On the other hand if you are like Colin McRae (rest his soul) and can handle a car any time under any conditions then go ahead and drive around all winter on your hockey pucks. It might actually be fun or something.
      08-05-2008, 09:04 PM   #16
montreal red
chris
montreal red's Avatar
278
Drives: White Boat
+1
i used to live in vancouver before i moved to montreal. i used summer tires year round because it only snows for bout a week there and when it snows, i dont use my car... although people say the summer tires loose a great deal of traction when the temperature drops, in my experience, you only really get into trouble if you try to use summer tires on the snows. in freezing temperatures with no snow, traction on summer tires really isnt that bad.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      08-05-2008, 10:02 PM   #17
ihyln
Drives: M3post sucks
2008 M3  [0.00]
2002 530i  [0.00]
if you plan on driving your car in winter, spending 1000 or so for a winter set is a small price to pay for what could happen to you otherwise. stop being cheap bastards or don't drive it in winter.
      08-05-2008, 10:36 PM   #18
Radiation Joe
Veni Vidi Vici
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Winter tires are awesome in near freezing weather. In anything above 40 - 45 degrees the summers are far superior. For most of the east coast, south of Boston, summers are the best choice.
If you want to be prepared for the 3 to 6 days per year you need the winters, and you don't mind the inferior performance the other 84 days of winter, get the winters.
      08-05-2008, 10:40 PM   #19
e46e92love
e46e92love's Avatar
Drives: e92 ///M3; X3 (wife's)
IF you want to not die, yes.
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan.
      08-05-2008, 10:45 PM   #20
elcarajo
elcarajo's Avatar
Drives: E92 M3, 6MT JzB/FR 19s no mods
No question at all regarding the need for winter tires in New England, but why specifically 18's?
      08-05-2008, 11:00 PM   #21
chris719
7334
Drives: '08 M Roadster
I drove a G35 Coupe last winter around NJ/NY/CT with Yokohama Advans (with plenty of tread left) until the first dusting hit. I was nearly unable to get out of a mostly FLAT driveway with about 0.25" of snow in 25 F temps. These problems would be exacerbated by the M3's wider tires. So, I would say that in NY you really should get winter tires.
Max performance summer tires like the Advan, PS2, RE050A/01R, PZero, etc are very very dangerous in the winter, if only because of the low temperatures. They have poor grip even in the dry, they become very hard at sub 40 F temps. I cannot tell you how bad they are when the roads were not perfectly dry, I would not even risk it at all. I had traction control coming on at 5 mph coming to a stop on anything that wasn't completely down to the pavement. My brother actually had it even worse with his 335i because of the slightly wider tires + lack of an LSD, had to be pushed up a hill and out of a friend's driveway after a tiny amount of snowfall.
I bought cheap wheels and winter tires from Tire Rack. I did my research and ended up with Michelin Pilot Alpin PA3, which were new for last year and BMW's recommended winter tire IIRC for the M3.
The dry handling of this tire is incredible for a winter tire... I'm fairly sure it is better than any all season out there. I felt that in the dry, this tire was almost at the level of a summer tire (in the summer!) when the temperatures stayed below 45 F. Bottom line, in near freezing temps, a winter tire will probably have more grip, even in the dry, than a summer tire.
The snow performance was decent, it probably isn't up to the level of the agressive WS60 Blizzak, but I got up a steep hill with about 2-3 inches of snow on it, and I felt very confident with it. I would go as far to say that I would feel more comfortable in a RWD vehicle with winter tires than a FWD car with all season tires. Downsize if you can, just make sure you keep your diameters within 3%. I ran the smallest wheels that would clear the brakes (17", to make tires/wheels cheaper) and 225's all around with staggered profile. Wider tires are not your friend in the rain or snow.
This year I'll be driving a Z4M Roadster in the winter , so we'll see how that works out. I'm sure it will be fine with snow tires, the ground clearance will be the biggest problem.
      08-06-2008, 12:32 AM   #22
Big Windy
Big Windy's Avatar
Drives: None
the general rule with winters is that the smaller and thinner (within reason) usually lends to better traction and control. 18"s with 245 is a good setup for the M3.
m3post
