05-13-2019, 05:51 PM | #1 |
76
Rep 322
Cylinder 1 misfires with rough idling
Hi,
my car recently started rough idling when starting the car. And error code of Cylinder 1 misfiring. First time, I just cleared the code and the second time I started the car, everything was okay. This afternoon, when I started the car after siting in garage for one day, it had rough idling again and a bit shaky, then the code came again. I have the tech check the ignition coil reI recently and it seems to be fine. I have BMS oil catch can installed right before the winter storage. And after a few days after taking the car out of winter storage , the code appeared. Now, I am suspecting that the OCC caused this misfiring. is there anyone here having this issue ? I am going to uninstall the OCC tmr and see what happened. |
05-13-2019, 07:38 PM | #3 |
1582
Rep 1,976
05-13-2019, 10:11 PM | #4 | |
76
Rep 322
rough idling/occasional misfire only happens when cold starting the car. After car moves, everything is fine, no rough idling. Kinda weird... |
05-14-2019, 09:20 AM | #5 | ||
2896
Rep 3,726
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
05-14-2019, 07:23 PM | #6 |
76
Rep 322
swapped coils between#1 and #2, same issue and still cylinder #1 misfire
Without OCC, still same. The car is at dealership now, waiting for full inspection. I searched the forum and now I am suspecting that my front O2 sensor may be bad which could lead to rough cold start. I don't drive a lot, once every 3 -4 days and the car was in winter storage for 6 months. |
clown1016.00 |
06-17-2020, 06:57 AM | #7 | |
Rep 21
Drives: bmw 740li M package bmw M3 30
Hey man I think I'm having the same issue here did they in any chance get back to you ? Thanks |
06-17-2020, 03:35 PM | #9 |
Rep 21
06-17-2020, 05:05 PM | #10 |
93
Rep 332
Maybe it's a bad spark plug. Have you checked the plug to see if it's roasted
06-17-2020, 05:06 PM | #11 | |
Rep 21
New plugs man 😓 |
06-17-2020, 09:55 PM | #12 | ||||
76
Rep 322
I bought two sets of spark plugs from dealership to get this solved completely. I found that stock spark plugs have QC issue. Both sets had one plug causing misfires (minor misfires but enough to notice when cold starting). I have OBD tool which can show the misfire counts on each cylinder so that I can know which plug is causing misfires. After replacing the bad plug with good one, the issue was solved. I paid everything out of my pocket. dealership is useless if they cannot diagnose the issue. They ran all tests including injector test on ISTA and told me the car was okay. lol. if you can replace the plugs by yourself, it won't cost you too much. Replacing plugs on S55 takes about 2 hrs. |
papasmurf_m3454.50 glo.kishaun0.00 |
06-18-2020, 07:24 AM | #13 |
Rep 21
Updated
BMW just called me and said that both o2 sensors is throwing the drivetrain light
And advised to replace both of them Part number : ( 11-78-7-848-482) Part number : ( (11-78-7-848-486) Hopefully that solves the issue : They don't have them in stock and told me to get them separately and the will fit them for me dumb dealers |
coldfish75.50 |
