BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
Mporium BMW
      05-10-2019, 11:44 AM   #1
Teerump
37
Drives: ‘09 Alpine White E92 M3
Bluetooth with iPhone audio?
Just got my E92 M3, I know to play music through the phone I have to connect the aux. and phone the the dongle in the center console. Is there a way to connect and play music wirelessly?
      05-10-2019, 12:40 PM   #2
Dpc2u
Dpc2u's Avatar
11503
Drives: E93 M3, E60 M5, F15 X5, E46
What year, cic, ccc, combox... Need more info. May be just coding changes for bluetooth streaming.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus
      05-10-2019, 04:02 PM   #3
Teerump
37
2009 E92 M3. How do see if it’s CCC or CIC, and how do I found out about combo box?
      05-10-2019, 05:12 PM   #4
Dpc2u
Dpc2u's Avatar
11503
A 2009 will not have a combox, therefore unless you want to do a complete OEM combox retrofit, your best bet would be an aftermarket bluetooth option. Just do a quick search for adding bluetooth for your model and year. Lots of good info on the forum.
Congrats on the new M3!
IG - @thebimmerhaus
      05-10-2019, 05:18 PM   #5
ItsGary
ItsGary's Avatar
1458
Drives: 2009 E90 M3
You have CIC.
You can retrofit the combox yourself if you want. Personally I don't think its worth buying the retrofit kits sold by the vendors here.
A used combox is $100usd
A plug and play wiring harness is around $120usd though you can do it yourself if you want.
MOST Terminator (Included in the PNP harness if you go that route) is $10usd
Coding if you can do it yourself then do it, but I'd say around $80 to $100?
I went the repin route so at the end of it, I only paid $10usd cause I got a combox and connector housing for free. The only thing I needed to buy was the MOST Terminator.
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD
      05-10-2019, 05:20 PM   #6
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
I use the wma3000b adaptor in my 08'. It works very well but if you listen to Bluetooth around your car with other speakers you have to lock your car or unplug it because it always takes priority over anything else. Even with the ignition off it's "awake" and ready to steal the connection from your other devices. It's annoying af...
9ers
      05-10-2019, 06:43 PM   #7
Teerump
37
I think I might go with the wma3000b adapter.
Thanks for the tip!
      05-10-2019, 06:46 PM   #8
Teerump
37
Hey, does it work well by leaving the adapter in side the center console?
      05-10-2019, 06:48 PM   #9
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
Yep that's where mine lives, it works too well apparently..
9ers
      05-10-2019, 07:00 PM   #10
Teerump
37
Cool
      05-10-2019, 07:37 PM   #11
wfdeacon88
1105
Drives: E90 M3
I have a Tune2Air connected and it sits in my console..it's phenomenal. easy connect and even easier than most built in Bluetooth connections, at least easier/quicker than my 2016 Tahoe. audio quality is top notch.
      05-12-2019, 02:08 AM   #12
bruinj26
9
Drives: Toyota 4Runner
TaoTronics Bluetooth Adapter
I've been using the TaoTronics BT Adapter. I found it on Amazon for around $15. It works great.
https://www.amazon.com/dp/B013QJ0W8Q..._Ey81CbA70SM5R
'09 E92 M3 Space Gray
'15 5th Gen 4Runner Trail
      05-12-2019, 07:29 AM   #13
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Retrofit nbt
m3post
