05-09-2019, 09:42 PM | #1 |
Rep 17
Some thoughts on BM3 tunes for my Manual F80 M3
I have used several BM3 tunes (CS, GTS, Stage1) for about 2 months on my 2015 manual F80 M3 (Non-ZCP), here are some of my feelings and thoughts:
First of all, the roar sounds pretty good when starting the car, and every OTS maps have this roar, but one problem is that when you enable the engine auto start and off in traffic, press the clutch, the rpm will hold at 2000 for a second, which sounds very loud outside and it is not a good experience. The power gain is pretty obvious for the 91 octane stage 1 tune, but all of the maps don't feel smooth for a manual car, for example, there is a little bit of hesitation when starting in 1st gear, and it a little bit of jerk in 2nd, 3rd even 4th gear when you let off the gas and press the gas again I can barely hear the exhaust burble even though I select 7 which is very aggressive and 1.5 sec of duration with the total stock exhaust. How does BM3 work in a DCT transmission? Do you guys have the same feelings as me if you got the manual? (ALL OF MY OPINIONS ARE BASED ON MY CAR(Manual)) |
05-09-2019, 10:33 PM | #3 |
Rep 17
05-09-2019, 11:35 PM | #4 |
118
Rep 137
Haven't tried the stage 1 tune yet, but with a CS map on my 15' DCT, throttle is smooth like stock. No hesitations or jerkiness. I'm guessing when you flash back to stock these issues you're having go away?
05-10-2019, 12:25 AM | #5 |
12
Rep 30
2018 M3 ZCP 6MT with 5k miles. I tried the CS+ map and wasn't liking the idle. It didn't "feel" right. I then switched to the CS map and have been running it since. I get the occasional jerkiness in the morning even though after warming up the car. I blip the throttle and it goes away.
05-10-2019, 05:46 AM | #6 | |
Rep 17
05-10-2019, 06:05 AM | #7 |
147
Rep 244
I' on BM3 stage 1 93 oct have the same trends on manual m4 when lifting off the throttle (like on highway traffic) and accelerating again in the lower gears makes it jerk, sometimes more than usual. This is remedied for me by pressing lightly on the clutch. Same jerkiness also happened when I first began to learn manual driving so I figured that's the norm with the initial adaptation reset and would take a bit of finesse/modulation until the car adapter to my driving style. It's much more less now, so could be that.
and, I don't use auto start/stop and kind of like the quieter exhaust (even though it's on one of the higher settings for a short duration.) There's a guy in my neighborhood with a 4 series that loves the gunshot burbles for what is probably the longest duration. To each their own, but definitely don't want to be grouped with him as those obnoxious BMW drivers by the lay person. edit: also haven't changed plugs as they were recently changed by BMW under 30k maintenance. |
05-10-2019, 07:22 AM | #8 | |
47
Rep 209
Alex |
05-10-2019, 07:39 AM | #9 |
515
Rep 554
Drives: 2018 M3 ZCP 6MT
I'm on BM3 93oct 18' ZCP M3 6MT
I haven't experienced any of these issues, but I also modulate the throttle by feel (doesn't everyone?) and I can't relate to any jerkiness issues...I've had and driven many different MT cars over the years, and this is a smooth ride- and for 500+ hp/tq. I also have no experience w CS maps or 91 maps..and I'm basically stock (w K&N dropins) |
Gtracer53.50 |
05-12-2019, 01:55 AM | #10 |
33
Rep 114
Drives: '18 M3 Verde Mantis
Anyone know who would be the best person on here to read logs and give suggestions? Is there anyone?
05-12-2019, 07:31 AM | #11 |
1125
Rep 2,564
I have a manual 2016 M3 (non-ZCP). Looking at the Stage 1 dyno curves, it seems like there is a tremendous rise in torque at low RPMs. Before reading this thread I always wondered how that would work with the M3 since the car already seems to be at the brink of traction at those RPMs when you roll into the throttle at lower gears. I can absolutely see jerkiness being an effect on this tune. I'm sure on the highway it is extremely effective but isn't this a tough tune to drive daily with the manual?
05-12-2019, 08:02 AM | #12 | ||
Rep 17
05-12-2019, 08:56 AM | #13 | |||
1125
Rep 2,564
It would be nice if this had a less drastic low rpm torque curve that just held on until redline. |
Mustoke13.50 |
05-14-2019, 03:08 PM | #15 | |
419
Rep 771
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
05-16-2019, 07:21 AM | #16 |
606
Rep 642
Hi, Johnny from Sweden here. i have a M4comp pack 2017 6-speed. I also have the Bootmod for my car that i used in my previous 2017 m4 so i will flash that into the one i have now. But i will lower torque on it. I feel that i don't need over 700Nm, especially not in 1st and 2nd gear. I will lower it in all gears i Think so i end up at the same torquenumbers as the GTS but with a bit more top end Power. that gives me a smoother Engine caracter and a feel that the Engine is pulling harder on higher revs, like a n/a Engine.
it also reduce the risk of a spun crankhub if you are worried about that. Johnny |
FY6.50 |
