05-07-2019, 11:51 AM | #1 |
79
Rep 260
How reliable is a stock block / stock internals 700-800whp build?
What's gonna go first on a build like that? I am amazed by how far this platform has come and am toying with the idea of picking up a $900-$1,200/mo M3 lease then doing some nice mods to it.
I'm just curious what the chances of blowing your engine / breaking something at 700-800whp are. |
05-07-2019, 12:41 PM | #2 | |
548
Rep 216
One other major factor you need to consider is high back pressure which can attribute to connecting rod failure. This is tremendously significant as many consumers with stock style manifold turbo upgrades were bending rods at 700whp-700+whp and were attributing these failures to rotating assembly limitations, when in fact it was due to high torque demands and high back pressure. One of our beta test vehicles has over 30k miles of hard driving and abuse with our KRAS55Bi's installed on a stock engine of which almost 10K miles of that was at 812whp daily driven on E85. The key to keeping the stock engine safe and reliable at that power level was reduced back pressure as result of our Patent Pending redesigned manifold with mathematically increased A/R ratio. Also, low torque demand is another contributing factor for safety and reliability as shown in our press releases. That being said, the answer to your question is yes you can safely produce 700whp-800whp as long as the you have the correct supporting mods. Good luck with your build and let us know if there is any way we can assist! Last edited by Sales@KRATOS; 05-07-2019 at 01:23 PM.. |
8
David0ff1059.00 M3anPower175.50 schnell1982345.00 scoobyhummel368.50 FriedPiston1972.50 FSociety3812.50 papasmurf_m3454.50 hatepotholez292.50 |
05-07-2019, 01:38 PM | #3 | |
79
Rep 260
My question is, can you make a "list" of what support mods are required for a 700whp-800whp build? I don't care if it's literally a marketing list that advocates every single product your company products. You guys obviously know what you are talking about and it'd be a huge help to me (and hopefully the community as well) |
scoobyhummel368.50 shu589200159.50 |
05-07-2019, 02:02 PM | #4 | |
548
Rep 216
List Of Modifications -Stock Engine -Stock Intercooler -ASR Downpipes -ASR Heat Exchanger -ASR Intake -Spec Stage 2+ Clutch Kit (Manual Transmission) (Dodson Sportsman Plus If DCT) Recommended -Fuel-It PI -Maximum PSI Crank Hub Kit -BootMod3 (HCP Custom Tune) -KRAS55Bi Turbo System -Pump E85 |
05-07-2019, 03:27 PM | #5 | |
79
Rep 260
I was reading about valve float. Is that only an issue at the big horsepower stuff like 1k+? Does your 800whp car have a stock exhaust system other than the downpipes? |
05-07-2019, 03:56 PM | #6 | |
548
Rep 216
The 812whp car does currently have stock head and our ASR exhaust. However, we've made over 800whp with the just downpipes on a stock exhaust. As far as valve float is concerned, you will run into valve float issues at the hp range you're looking to produce. You can mitigate that by adding a MILV's kit. What we found while working with Headgames was that if we had the MILV's kit installed with stock springs and increased lift, this would have created coil bind. Normally coil bind is a bad thing, however in this case the coil bind would have minimized the valve float. Either way, even with float happening our KRAS55Bi continued to climb in power on the stock block and head all the way to the 7500rpm limiter. |
05-07-2019, 06:55 PM | #7 | ||
516
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
05-07-2019, 07:21 PM | #8 |
548
Rep 216
This 812whp figure was achieved at 32psi on pump E85. Our goal was to limit power output to 800whp as a matter of discretion being that the engine and cylinder head were stock. However, these results were attained utilizing the previous iteration of our forged billet compressor wheel. Our latest production version compressor wheel supports an additional 10% VE over that of our previous design with no increase in lag as results have shown.
For more information on these stock engine results, please reference our previously posted press release listed below. https://f80.bimmerpost.com/forums/sh...ghlight=KRATOS Last edited by Sales@KRATOS; 05-07-2019 at 08:48 PM.. |
M3anPower175.50 |
05-07-2019, 08:34 PM | #9 | |
79
Rep 260
05-07-2019, 09:13 PM | #10 | |
1582
Rep 1,976
Unless you’re just looking for low payments and then buying out your lease at the end. |
05-07-2019, 09:59 PM | #11 | |
79
Rep 260
I have an E63S AMG now and it uh... it just ain't cuttin it. Itching for something else. Turbos, downpipes, intake, maybe exhaust, no big deal. Port injection, probably a big deal to take off at lease end. Crank hub kit... let BMW keep it... you think they'd really notice? Heat exchanger would be another thing that would probably need to come off. Clutch, let them keep it. |
05-08-2019, 07:06 AM | #12 | |
1397
Rep 3,152
05-08-2019, 08:40 AM | #14 | |
548
Rep 216
Our built engine S55 produced 1163whp/983wtq @ 41psi on Ignite E85. However, we have been using torque reduction as well as lower boost targets for testing at the track and half mile due to traction issues as well as drivetrain preservation. |
FriedPiston1972.50 papasmurf_m3454.50 |
05-08-2019, 08:53 AM | #15 | |
548
Rep 216
Here's a sneak peak! |
05-08-2019, 01:12 PM | #16 |
1397
Rep 3,152
lol, no, I was serious. They'd never be able to tell unless they opened 'er up.
05-08-2019, 02:37 PM | #17 |
79
Rep 260
05-08-2019, 03:00 PM | #18 |
373
Rep 500
Why not just BUY the car if you are considering so much modification? Or pick up a low mileage used and work from there
05-08-2019, 03:07 PM | #19 | |
1397
Rep 3,152
You can resell any of the mods you're talking about doing; on a 3 year lease, nah, its not too much. Side note, I didn't lease this f80 like my last one, but my upgraded hub is being installed today.
05-08-2019, 08:20 PM | #20 | |
79
Rep 260
05-08-2019, 08:31 PM | #21 |
79
Rep 260
Anybody want to tell me how these prices look / what labor would look like? I couldn't find the ASR heat exhanger on Google, if Sales@KRATOS wants to throw a link or a price for the part.
Not sure if more expensive downpipes are needed, or if a more expensive tune is needed. You're looking at about $16-$17.5k in parts shipped, then I'd imagine easily 10-20 shop hours at $100/hr = $2k? |
05-08-2019, 08:47 PM | #22 | ||
1397
Rep 3,152
A lot of people are getting this done for 2500-2700 all in including parts.
