05-05-2019, 12:31 AM | #1 |
174
Rep 532
How do I remove the cover from the fuse box in the engine bay?
Is there a trick to removing the fuse box cover underhood (passenger side cowl area by the red “+” terminal)?
I got the cover loose but could not get it out under the bracing without literally breaking something, and I needed to get to a couple fuses in there. Tried everything. Are you supposed to remove the M car bracing? The only way I eventually got it out was by ham-fisting it, getting pissed, and mangling it a bit. I bent it so hard it got all scuffed up and the corner of the fuse box cover broke off. I know there's another way... |
05-12-2019, 11:00 PM | #2 | |
49
Rep 239
05-12-2019, 11:30 PM | #3 | |
1973
Rep 2,711
05-29-2019, 07:14 PM | #4 |
44
Rep 137
Every time you remove the strut brace you're supposed to replace the bolts to get correct torque. I can get my cover off without it, but it's scratched pretty badly from doing it.
