04-29-2019, 07:30 PM | #1 |
Roll Tide
285
Rep 579
Exhaust has developed an odd noise
So I just got my car back after having catless downpipes installed. The whole system is an Active Autowerke's exhaust. The shop took the whole exhaust off the car while doing the downpipes and my first thought about this noise is that a joint came loose. If you've seen the AA exhaust it's really crazy with the nuts and clamps.
Because I have the catless downpipes I hear things I never heard before and need some insight from guys who know what things should and shouldn't sound like. Here's the clip and it's the tinny rattle you hear coming off throttle that I'm concerned with.
AW/SO - ED delivery 6/20/16
PCD - 9/1/16 |
04-29-2019, 07:48 PM | #2 |
2516
Rep 2,079
It’s an exhaust leak. Take it to the shop and have them do it right. Ale sure they replace the one-time-use-only gaskets
Check out this video |
04-29-2019, 08:56 PM | #3 | |
Roll Tide
285
Rep 579
I have a clip where I recorded the dp area and that section isn't moving that I can tell. I know I can take it back to have it looked at but it's a lot of hassle if I can reposition a clamp on my own and be done in less time than driving it over there.
PCD - 9/1/16 |
04-30-2019, 05:05 AM | #4 | ||
2516
Rep 2,079
Those clamps are actually very poorly designed. In my video when I out everything back together I also had a leak at the rear clamps. After repositioning them I'm good to go. Oh and be sure not to get under the car with just s jack. Use some backup |
03-22-2021, 11:26 PM | #5 | |
Wing Chun Shifter Speed
36
Rep 181
03-23-2021, 07:07 PM | #6 | ||
Roll Tide
285
Rep 579
PCD - 9/1/16 |
TopJimmy5460.00 |
