04-27-2019, 01:50 PM | #1 |
36
Rep 286
Air conditioning memory coding.
Update
This is how it's meant to work. Now when I turn it off it will stay off. If I have it on and set to a temperature and turn the car off it will come on at the same temp. This is how it's meant to work ! Hi guys tried to code this auto function off today. It coded ok I waited about 5 minutes in the car after coding. I didn't really notice any blinking so I just turned the car off. Went back to it and it came on as usual. So went back to check the coding and sure enough it's showing as being coded off for both the bottom two options I left the top one to auto. (Followed instructions from YouTube for a f30 but it had the same options so thought it should work) Has anyone successfully coded this? Thanks Last edited by Thewrench86; 04-30-2019 at 09:24 AM.. |
