04-27-2019, 10:20 AM | #1 |
169
Rep 1,039
New crankhub fix - Litchfield
https://www.litchfieldmotors.com/blo...rank-hub-issue
Is this any different than those on the market? Bolt capture looks different. Last edited by parabmw; 04-27-2019 at 10:31 AM.. |
04-27-2019, 10:50 AM | #2 |
2228
Rep 1,897
Interesting find and thanks for posting. It was good they provided context for what the issue is, why it happens and how. I also didn't know Litchfield was tuning the F series.
04-27-2019, 11:16 AM | #3 |
174
Rep 532
Interesting and thank you yes. Can someone explain what this "capture plate" actually does ? / how it works ? I See it but... can't see how it does anything.
04-27-2019, 03:34 PM | #4 |
505
Rep 2,152
i am worried its not keyed or pinned to the crank like the gintani or maximum psi. what is to stop that from spinning on the crank?
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
04-27-2019, 03:42 PM | #6 |
505
Rep 2,152
yea the gintani you drill the crank and a nob on the hub is effectively keyed and stops the hub from spinning and the MAXPSI one you drill 2 small holes and pin it to the crank
the litchfield one doesnt do any of this. its just a 1 piece hub not keyed or pinned
04-27-2019, 04:27 PM | #8 | |
985
Rep 1,885
Doesn't project a lot of confidence that there product actually resolves the issue. The other issue is this is by far a tuned car issue. To say that this occurs in any significant way in stock cars is misleading. There are a handful of cars where this has occurred in stock and I bet they were shifting errors. |
04-27-2019, 04:48 PM | #9 |
176
Rep 342
04-27-2019, 05:26 PM | #10 | |
88
Rep 173
04-27-2019, 05:28 PM | #11 | ||
985
Rep 1,885
Of the stock cars - how many were tuned at one point ? I'm confident the transmission type plays no role in the statistical chance of this occurring. If you keep the car stock - you have a greater chance of winning Lotto than you have of spinning the crank hub. |
04-27-2019, 07:43 PM | #12 | |
88
Rep 173
The e46 and the e9x had there design/engineering issues (and please recall their crank hub was keyed and could handle a supercharger bolted on). This is the F8x’s issue. Is it more likely to fail if pushed, probably. But the fact that it happens to stock cars demonstrates it’s an issue. The DME actually measures the engine going out of time and completely shuts the engine down with too much deviation...there is a sensor for this...thus they knew it could slowly let go and the system can attempt and hopefully catch it before pistons hit valves. Most engines just need to be retimed and a new hub. And remember this part is smooth machined steel pressed together with a bolt torqued to 100 NM and stretched 270 degrees, but a base motor makes 550 NM of torque; that’s the force this crank sees a lot...and go figure they’re going back to a keyed hub on the B58/S58. |
04-27-2019, 07:50 PM | #13 |
88
Rep 173
And just to be clear, I love my M4 and am keeping it indefinitely. I paid cash to repair with an upgraded aftermarket hub from maximum PSI at my local shop. This will continue to be my track car and occasional DD. I’m merely pointing out this isn’t the first M engine that’s had an issue and BMW is not infallible. Porsche had the IMS issue. Every car in this category has something. It’s found, fixed, and you move on.
04-27-2019, 07:55 PM | #14 | ||
985
Rep 1,885
Stock cars - completely stock - are extremely unlikely to spin the hub. A stage 2 tune with downpipes is running outside of the manufacturers specifications - by a fair margin. This is a "weakness" unmasked by high levels of power often delivered in an unpredictable way by tuners of varying quality and experience. |
04-27-2019, 08:01 PM | #15 |
88
Rep 173
Call any reputable shop like Bimmerworld and they’ll tell you they see plenty in all forms from stock to race prepped. I’m providing facts as well as a large sample size from reputable/expert shops who aren’t trying to sell you anything. Bimmerworld even said they don’t recommend doing it prophylacticly but if it spins, get an upgraded hub at that point.
I’m just passing on the knowledge I’ve gained from those who know more than either one of us. Do what you want with it. Too many people spouting unhelpful opinions as fact. |
04-27-2019, 08:14 PM | #16 | |
4922
Rep 3,805
04-27-2019, 08:25 PM | #17 |
88
Rep 173
This has been reported for years in all model years. Who said it was a death sentence? Retime and stock hub replacement at the dealer is~3k and that’s all the vast majority of spun hubs need. I paid 3.8k to a local shop for upgraded aftermarket parts on the recommendation of multiple race shops.
Thanks for illustrating my closing comment earlier. |
04-27-2019, 09:19 PM | #18 | |
4922
Rep 3,805
04-27-2019, 09:51 PM | #19 | |
88
Rep 173
You and I may have different opinions on some things here, but we both are sick of the misinformation, and that is what I’m trying to help clear up as well. |
04-27-2019, 10:50 PM | #20 |
17485
Rep 10,663
Drives: M4 CS. Former G82, x2 F82, F80
I've checked with several shops in my neck of the woods, both official BMW and indies whom I've known for years. Nobody has heard of a single spun crank hub, they didn't even know what the hell I was talking about. All gave me the old "everything is a horrible disaster on the internet" speech.
04-28-2019, 04:16 AM | #21 | |
7334
Rep 7,298
04-28-2019, 07:04 AM | #22 | |
176
Rep 342
