04-24-2019, 01:38 PM | #1 |
Rep 27
Can I install BM3 tune without removing JB4?
I did some searching and research on this. I have seen some helpful information but have not seen a direct answer to the question. I have a JB4 tune on my F82 M4 currently. It is Stage 2. So it has piggyback connections to the TMAP, the MAP, and the OBDII. It also has the bluetooth unit.
I am inclined to think that, since these are just piggyback connections, that I can simply set the JB4 to inactive (Map 0 or Map 4) and install the BootMod3 tune over top of it. Is this safe? Will they interfere with each other at all? My main objective is to avoid the headache of going through the engine bay and disconnecting all of the JB4 parts if it is not necessary to do. And it could be beneficial to leave the JB4 hardware installed in case myself or a future owner wants to switch back to that in the future. |
04-24-2019, 01:48 PM | #2 | |
BimmerPost Supporting Vendor
8209
Rep 18,823
Drives: BMW
04-24-2019, 02:57 PM | #3 |
3072
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
oops. any reason why?
that being said OP, i always put the JB4 on Map 0 and flashed without issue.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
04-24-2019, 03:04 PM | #5 | |
8209
Rep 18,823
Drives: BMW
If you have an older JB4, remove the can wires to be 100% safe.
04-24-2019, 03:23 PM | #6 | |
Some random guy
292
Rep 312
The JB4 stays on Map0; obviously, need to remove the OBD connector from the JB4 to flash with BM3. So far, multiple flashes without issue and the real-time monitoring and auto-logging functionality of JB4 is maintained when I reconnect the OBD after completing a flash. Logs with this configuration have been much cleaner than the MHD+JB4 setup I was running and the smoothness of running the DME flash tune is incredible. Best way I've been able to explain it is a feeling that the car is now functioning with 1 brain at the controls, rather than the 2 minds of the JB4 and DME trying to balance out and provide a performance boost. Worth noting - keep in mind that if you have the latest JB4 firmware Map4 no longer serves as a safety/monitoring. It is now set up as a low boost "valet mode" map. Probably best to avoid using that one.
04-24-2019, 04:00 PM | #8 |
24198
Rep 190,805
Should not be a problem with Jb4 being on map 0, you can also disconnect the OBD connection when flashing the car and connect it once you are done
04-24-2019, 04:04 PM | #9 |
550
Rep 949
With the OBDII cable out the JB4 is off CANbus, so just change it to map0 and it's along for the ride.
What many of my flashed customers do is update the JB4 firmware, set the FUD bit for a back end flash, and then map1 becomes your flash only map where the JB4 is doing zero tuning and only allowing logging, in dash gauges, CANflap control, and stuff like that. If it's along for the ride might as well use some of it's features. And of course BMS offers free flash maps you can load via BM3 or MHD that are specifically designed for a variety of uses like full E85 depending on what your needs behind the wheel are. Last edited by Fuel-It!; 04-25-2019 at 10:04 AM.. |
07-31-2020, 03:56 PM | #11 |
Rep 13
Any feedback on whether or not this worked? I have JB4 installed current with Bluetooth and I want to flash my M3 with Bm3. Don't want to disconnect the JB4 plugs just yet. Just got my Bm3 license.
07-31-2020, 06:06 PM | #12 |
550
Rep 949
Just leave JB4 on map0 to start, tons of people run flash maps with the JB4. Later as you get more confident you can enable certain JB4 features for fine tuning for example.
08-10-2020, 06:16 PM | #15 |
Rep 13
JB4 Running With BM3
I switched over to BM3 today. Running Stage 1 91 ACN. Kept JB4 installed. JB4 has to be in Map 0 if you have a newer one. The older models used Map 4 for data logging only. Not the case any more. You can still data log with the JB4 in Map 0 and connected to the OBDII port. So far so good.
