European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      04-21-2019, 11:36 AM   #1
tavio1227
33
Drives: F80 M3
Help coding off side markers in Xenons
Hello I want to code off the side markers on my f80 I have the E-Sys program but the launcher won't work. Anyone can help me out? Thank you
      04-21-2019, 02:55 PM   #2
kubax86
BimmerPost Supporting Vendor
kubax86's Avatar
1790
Drives: M2
Can help via TV. Pm me
      04-22-2019, 11:53 AM   #3
backagain
just a fool
backagain's Avatar
China
345
Drives: 2016 SO coded M3
The launcher expired at the end of 2018. You'll need the re-arm program, https://f30.bimmerpost.com/forums/sh....php?t=1457494. Pretty straight forward.
Good luck.
      04-22-2019, 01:12 PM   #4
tavio1227
33
Drives: F80 M3
Good luck.
Thank you sir, now I'm getting an error after the launcher (connection to e-sys launcher failed. Restart and try again) but e-sys program still open but can't connect with the car it won't let me hit the connect bottom
      04-22-2019, 03:49 PM   #5
backagain
just a fool
backagain's Avatar
China
345
Without re-arming and adjusting the date, can you connect to the vehicle and get the VIN?
If the launcher is working properly, you should be able to start the program; connect to the vehicle; read the FDL file; but can't edit the FDL file because it will ask for the token repeatedly. This is where the re-arm program is needed. So make sure you launcher is working properly.
f80post
