04-13-2019, 06:50 PM | #1 |
Rep 43
Bootmod3 OTS Stage 2 CEL issue
Hey guys, I am having some problems with my BM3. I just put on my catless downpipes and AWE track exhaust. I tuned the car today and when I first tuned it the CEL went off from the downpipes. However on the second drive cycle the CEL came on BM3 shows code 128C01 "Lambda probe before catalytic converter, shoring: probe not properly mounted in exhaust system". I have turned off catalyst monitoring with the tune and every second drive cycle that code sets. The shop that help me install the exhaust is saying it is because there are no cats in the downpipes. I have attached a picture of the laptop screen with the code.
Also what is the BM3 burble setting with this tune. I was messing with the Burble settings and now the burble is set to OEM. Which is the best mild aggressive burble setting? Thank you in advance any help would be greatly appreciated -Anthony |
04-14-2019, 07:02 PM | #4 |
Rep 43
04-14-2019, 07:05 PM | #5 | |
Rep 43
Cat #2 would be the rear cat the "small" one correct ? |
04-14-2019, 07:15 PM | #7 | |
721
Rep 364
Pre cat must be fully functional to read AFR. |
04-16-2019, 09:53 PM | #8 | ||
Rep 43
Just got the car back from the shop again today, The shop told me that all exhaust sensors were reading on their scan tool. He said he reset adaptation for them and the CEL is now staying off. I reached out to BM3 and SSR Performance, they did confirm that sometimes the system needs to have the adaptation reset. |
04-17-2019, 12:03 AM | #9 | |
BimmerPost Supporting Vendor
24198
Rep 190,805
11-27-2020, 01:40 PM | #10 |
48
Rep 108
Reviving this thread.
I'm running into the same issue. I've been running a custom E30 tune for over a year, and the problem started happening after I switched back to the custom E30 tune AFTER running a custom 91 tune for a weekend (long road trip). Any ideas? I've reset the adaptions and flashed to the E30 tune again for good measure, but still throwing the code after awhile. |
01-03-2021, 12:54 PM | #12 |
5460
Rep 5,153
If you are getting an error on one of the the two pre-cat O2 sensors then reset adaptations and try, re-flash and try, and then look for physical problems with the wiring or sensor. A CEL or Code on the pre-cat sensors is a real fault. On the post-cat a CEL is usually just the low-value reading (but if post-cat fails there is a different error).
Another way to re-push the full flash is to flash to Stock (don't lock) then re-flash to Stg2 E30 again.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
01-04-2021, 04:03 PM | #13 | |
48
Rep 108
01-06-2021, 12:23 PM | #14 |
Connoisseur
236
Rep 336
Drives: 2016 F82 ZCP
Very interesting... I also got a lambda code right after catless downpipe install and flashing BM3 stage 2 OTS (code is different than yours) but still relates to the o2 sensor. Haven't been able to dig into it lately with the snow/ car in storage but it's really annoying.
Instagram: @dmikucki
01-06-2021, 04:02 PM | #15 |
48
Rep 108
I was able to get underneath the car yesterday. O2 sensors are not loose and wires look fine. I flashed to stock then back to my custom e30 tune--code came back. I'm taking the car into the shop next week to get both O2 sensors replaced. Since this started happening, the car has an extremely rough idle on startup. It sometimes doesn't go away until I start driving. I assume because the AFR readings are out of whack.
I've been running DPs and the custom tune for almost two years without issue. The only thing I can infer is the O2 sensors are starting to go bad, but not bad enough to where I"ll get a specific DME error telling me they are bad. But yes....annoying. |
tucked_m463.50 |
11-21-2021, 04:46 AM | #16 | |
Rep 21
11-29-2021, 07:32 PM | #17 |
48
Rep 108
tropicatango437.00 |
