GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      04-08-2019, 02:57 PM   #1
brotatoe
Drives: 2018 Alpine White M4 ZCP
Silicone Charge Pipe + Engine Cover Fitment Issues?
I had to replace my factory charge pipes since they cracked and decided to go with a pair of Vargas Racing silicone ones...but I can't get my M POWER engine cover to fit over them...anyone else have an issue with this? I could cut the cover up to clear the larger diameter of the hose but that seems...whack. I tried adjusting as much as I can but that grommet that separates the charge pipes is just not making contact.
Ideas? Tips?
      04-09-2019, 10:45 AM   #2
Ferg
Master of my own domain!!
Ferg's Avatar
153
Drives: F82 M4/F15 X5
I ordered an extension nipple (or whatever you call it) from ESS. They kind of gave me a hassle, but did it for me. It's not cheap; however, I could not bear having the cover sitting there.
      04-10-2019, 12:15 PM   #3
brotatoe
Oh, interesting---and it doesn't make contact with the hood? For me it rattles if it's too high up.
      04-10-2019, 12:43 PM   #4
Ferg
Ferg's Avatar
153
Clears perfectly.
      04-12-2019, 07:00 PM   #5
slaughter.mode
slaughter.mode's Avatar
Drives: 2018 M4 Competition
2018 BMW M4 ZCP  [9.80]
Clears perfectly.
I tried googlin' it and came up empty, do you have the link to it?
      04-13-2019, 07:40 AM   #6
MGF82
63
Drives: F82 M4
Ideas? Tips?
I installed the Vargas ones a few weeks ago and didn't have any issues. Make sure the pipes are all the way seated at both ends. If not they will sit up slightly higher not allowing the cover to fit.
      04-15-2019, 09:31 AM   #7
brotatoe
Yeah I went through that a few times to make sure but there's no way the engine cover will clamp down on that nipple between the charge pipes. They even said (Vargas) they had to trim the cover to clear it properly. I might just do that.
      04-15-2019, 09:36 AM   #8
Ferg
Ferg's Avatar
153
https://esstuning.com/contact-us/
Just let them know exactly what you are requiring. This is how they describe it.
"The ESS charge pipes are slightly larger than the OEM counterpart, creating a need for the engine cover extension socket that is included. The engine cover socket raises the back of the S55 engine cover enough to accommodate for the larger outer diameter of the pipes, but not too much as to interfere with the underside of the hood when closed. "
      04-15-2019, 09:46 AM   #9
slaughter.mode
Right on, I'll do that. Thanks!
      04-15-2019, 11:57 AM   #10
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
You can see the hardware included wit hthe ESS Silicone Charge Pipes in the image below:
We always keep the Charge Pipes in stock, let me know when ready for a set.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      04-15-2019, 12:28 PM   #11
slaughter.mode
I just need that little extension adapter for the grommet, how much are they?
      04-15-2019, 12:34 PM   #12
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Not sold separately, only part of the ESS kit.
      04-15-2019, 01:15 PM   #13
Ferg
Ferg's Avatar
153
I had to work directly with them and it was not cheap.
      04-15-2019, 03:01 PM   #14
slaughter.mode
Oh, I'll fab. one. It's not a big deal. Thank you!
I got a quote from EAS saying it would be ~$100 for that part if anyone is interested, most likely not (lol).
      09-15-2019, 10:19 AM   #15
Trevorstein
Trevorstein's Avatar
150
Drives: Trabant
Definitely not!
Could you measure it? How tall(er) is the extension - from base to nipple in mm's??
Greatly appreciated!
Cheers!
///M Joy
      09-15-2019, 05:12 PM   #16
blockdoc
Drives: 2015 M4
Originally Posted by Trevorstein View Post
Definitely not!
Cheers!
FWIW, I had the same issues with fitment with my aluminum (VRSF) pipes. Rattled.
Finally just took the cover off and problem solved! I mean, what does it really do with the hood closed, lol.
There have been some threads about lowering IATs with the cover off. Who knows
      09-15-2019, 08:55 PM   #17
Trevorstein
150
Drives: Trabant
I hear ya! I've actually heard the same.
I only take it off for Track Days, though.
Cheers!
///M Joy
      01-15-2020, 12:49 PM   #18
Weisslan
12
Drives: 2015 M3
Definitely not!
Cheers!
Did anyone figure out a work around or a place to just buy the extender?
      01-16-2020, 10:55 AM   #19
Trevorstein
150
Drives: Trabant
Not needed. Just unthread the existing one a couple of turns counter clockwise ("Loctite" if needed) and that should solve it!
If you really have to have it, ESS will sell you an extended one - for $69.00!!
Cheers!
[Edit:] "Loctite" wasn't that "tite". The nipple loosened up and disappeared!
///M Joy
      01-16-2020, 11:36 AM   #20
nbennettksu
1397
Drives: DV F80
weird, my ESS kit came with the extension
Originally Posted by JBasham View Post
Caddy ATS . . . finally, a decent rental car option.
Originally Posted by kchu221 View Post
the wheels make me mad...
Originally Posted by mhabs View Post
It's one thing for some buffoon to put an M badge on something that doesn't deserve it...it's another for a multi-billion dollar corporation to do the exact same thing and keep a straight face.
      01-17-2020, 11:02 AM   #21
metomwhou
80
Drives: 2015 M4 YMB/6MT
I think they're talking about using another kit and only trying to get that specific part from ESS.
2015 YMB M4 "Kimber" / Stage 2+ tune by Alpine MSS / FULL VRSF Bolt-On: Charge Pipes/Front Mount Intake/Downpipes/Mid-Pipe / KW HAS / HRE FF01
https://f80.bimmerpost.com/forums/sh....php?t=1466873
      11-27-2021, 09:31 AM   #22
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
Found a solution to the engine cover issue. Added this to the engine cover mount and have had no issues and no rattle.
Car Enthusiast.
Appreciate 2
hellokitty2895.50
djpeetur170.00
f80post
