04-07-2019, 09:46 AM | #1 |
-1
Rep 7
Bootmod3 E30 Mix
I’ve been searching through forums looking for some dyno sheets but there aren’t many. I found 2 for stage 2 93 but i didnt Find anything for BM3 E30 mix. I’m just trying to get an idea on how much power is expected to be made on the E30 mix. If anyone can help I’d appreciate it thanks alot🙏🏼
04-08-2019, 02:17 PM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
530-540whp / 550-560wtq
60-130 7.8-8.0s 100-200 (EU) 6.5-6.8 LMK if any questions
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 04-08-2019 at 04:06 PM.. |
05-31-2019, 02:35 AM | #5 |
52
Rep 107
06-01-2019, 10:42 PM | #6 |
139
Rep 103
06-01-2019, 11:31 PM | #7 |
IG @bmwF9xG80
3813
Rep 7,593
Tested in my own car stock hardware and with DPs is more consistent and sometimes 0.1-0.2 better times 60-130
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
06-01-2019, 11:45 PM | #8 | |
355
Rep 719
OTS e30 map 100-200 low 8s I start the run 3rd gear about 70-80 km/h and run it into 4th gear you better of shifting at 6.5k, no point spinning it to 7.5k turbo runs out out of puff way sooner at high altitude Last edited by whoop_ass; 06-02-2019 at 12:12 AM.. |
mdma-zn51.50 |
06-01-2019, 11:50 PM | #9 |
1973
Rep 2,711
JB4 in Map 7 (~24 psi, no BEF) with E30 does around 505whp on a dynojet. Expect the BM3 E30 OTS with lower boost target to dyno about the same or ~5whp less.
I ran the 100+ octane BM3 OTS map (22 psi) with roughly 99.1 octane fuel, and that felt like a 505-510 whp car. Full E85 on stock boost should get you somewhere between 520-530whp... load the free BMS E85 map via BM3 to get a taste of what full E85 feels like. |
06-02-2019, 06:24 AM | #10 | |
52
Rep 107
Thanks J! Your way also works for me as oppose to a 4th gear pull without a gear change. At an Abs ambient pressure of 12.5 psi and with Cary's 1st revision map I have barely broken into the 6's with the help of a slight decline. |
06-02-2019, 10:42 AM | #11 | |
355
Rep 719
The cold weather is helping allot but that's a great result. |
06-03-2019, 11:29 PM | #12 |
BimmerPost Supporting Vendor
24198
Rep 190,805
We are running the E30 map on the shop's M4, love the power
I will be putting the car on the dyno when i get a chance
02-07-2021, 10:32 AM | #13 |
553
Rep 815
Mate just tried out BM3 stage 2 E30 map tonight on 100% stock plugs. His only mods are catless DP, and SSR intakes.
OTS stage 2 93 - 100-200kmh 7.9 OTS stage 2 E30 - 100-200kmh 7.3 This is on completely flat road. DA600m temp 26*c Unfortunately we didn’t log any of the runs. Does the E30 map run higher boost that 93? Or is it purely the ignition timing advance? |
11-27-2022, 06:27 PM | #14 | |
664
Rep 1,074
Instagram: M2_Medusa
11-28-2022, 08:33 AM | #15 |
24198
Rep 190,805
Contact BMS
Tags |
bm3, bootmod3, e30, f80, ots, s55 |
