04-01-2019, 08:32 PM | #1 |
20
Rep 30
Wondering if anyone has been able to use Bimmercode to reduce the BSM occurrence to 20 kmh instead of the default 50 kmh?
I saw someone had posted this before that it's possible with going into the ICMQL module in expert mode (screenshot below)... But I don't see expert mode as an option in the ICMQL module in Bimmercode. Am I missing something? |
04-02-2019, 06:47 AM | #2 |
1023
Rep 1,168
IIRC it won't work below certain speed regardless of the limit you code.
covertstyle20.00 |
04-02-2019, 12:56 PM | #3 | |
41
Rep 108
For me, in ICMQL I have the following available: - Active Cruise Control default distance - Default driving mode - Driving mode memory No other options and nothing for Expert Mode. |
covertstyle20.00 |
04-02-2019, 06:30 PM | #4 | ||
20
Rep 30
I reached out to Bimmercode and their response was that expert mode is disabled in the ICMQL module for "safety reasons". I'd really like the BSM to kick in at lower speeds so eventually, I'll probably bite the bullet and go to Esys route to code it. It's comforting to know there's plenty of folks here with expertise in coding the manual way so it's not necessarily uncharted territory! For those that have done it via Esys, how difficult is it to code the BSM to 20 kmh? |
CanadianLurker41.00 |
04-02-2019, 09:40 PM | #5 | |
Rep 21
Active Blind Spot at lower speed ICM 3000 C_ZSW_Aktivierunggeschwindigkeit_Funktion_low 50kmh (default) 20kmh (lower gives error) |
CanadianLurker41.00 covertstyle20.00 |
04-04-2019, 05:51 PM | #6 |
4145
Rep 7,160
Drives: F90 M5 / F15 50i
I set it on mine.
'07 Yamaha R1 (sold)
04-23-2023, 11:54 PM | #8 | |
38
Rep 322
Why below 20 kmh give error? Can I set blind spot monitor to work while car is parked like safe exit assist? |
