03-31-2019, 09:35 PM | #1 |
20
Rep 53
Need help following some coding instructions (Changing typschussel)
Hi All,
So I've coded some basic things, easy seat entry, remember start stop etc... so have the basics down. Then I found this and I'm confused... https://f80.bimmerpost.com/forums/sh...52&postcount=2 It says to change typschussel to 8M93 If I connect to my car with SYS, read under Vehicle Order, then expand the FA folder then expand FZAuftrag->Type I can see Typeschussel and my value is 3R92 but I cannot change this value. When I right click on it all the options are grayed out (But the options are, Activate FA, expand and collapse) Then it says find VDC then code DSC, does this mean to right click on these under SVT and hit the code FDL button like you would after you have edited FDL? (But in this instance no FDL changes have been made?) Thanks for the help in advance! |
04-01-2019, 02:27 AM | #2 |
184
Rep 760
I don't have the program open but you need to edit the FA to change your type. When they say to code, they mean right click on the module and click code. It basically applies all changes to that module so any FDL coding you did to the module before will be wiped out.
14 Audi S4 (sold)
16 BMW M3 (sold) 16 VW Golf GTI (sold) 20 Tesla Model 3 23 Audi R8 (on order, never came ) |
04-01-2019, 04:19 AM | #4 |
20
Rep 53
I think I see my problem. I have only done FDL coding, this is a VO coding which is a different process.
So I think I need to hit save after I read, then I can edit and it goes into the FA editor and I should be able to change typschussel. As I haven't done this before I want to double check I'm doing it right. A document I found says after making the FA changes, I have to load the file, click on Calculate FP then on the VCM master tab click on Write FA FP. (If I do this does it mean all my previous FDL coding will be lost?) At this point will it show all the ECUs and I just need to code the VDC one like I would as if I was coding a FDL change? Also is it the VDC or DSC ecu? |
04-02-2019, 03:23 AM | #5 | |
184
Rep 760
14 Audi S4 (sold)
04-02-2019, 07:49 PM | #6 | |
39
Rep 134
"A document I found says after making the FA changes, I have to load the file, click on Calculate FP then on the VCM master tab click on Write FA FP. (If I do this does it mean all my previous FDL coding will be lost?)" write FA FP only writing the customized FA code, not all your previous FDL coding will be lost, only on the corresponding module you VOCoded with the custom FA T
Instagram: @tafikhulafaa & @88tuning.id
04-03-2019, 05:02 AM | #7 |
20
Rep 53
Once I edit the VO and code the VDC ECU, is this the same as changing a bunch of the FDLs in batch?
If so is the only way to know if it's worked (apart from noticing the difference in the car) is to compare the FDLs before and after for the VDC ECU? |
04-03-2019, 08:26 PM | #8 | |
Christmas Poo
1029
Rep 1,180
Hope that helps.
Read...no drive, the manual. |
