      03-21-2019, 11:29 AM   #1
schmidtp
59
Drives: 2008 BMW 135i 6MT
2008 BMW 135i  [0.00]
2019 Ram 1500  [0.00]
Tire Size Recommendations
Hi All,
Started to search but with so many threads I thought it would be more efficient to ask the fitment experts on forum.
For the past couple summers I have been running tire sizes from the stock set up. Unfortunately I have had to replace a couple tires from road hazards and haven't had the chance to replace the entire set but I am now. Here is the current setup.
Front 18x8 215/40
Rear 18x9.5 245/35
I want a more squared off, meaty look without adding height. The rears are far too stretched for my liking and the fronts could possibly have a new size too. What are your recommendations for common tire sizes? 225/40 and 255/35? Car is not lowered and rims are pretty flush to fender.
Thanks,
Patrick
2008 TSM 135i N54
      03-21-2019, 06:28 PM   #2
asbrr
545
Drives: 2014 335ix M-Sport
Originally Posted by schmidtp View Post
Hi All,
Front 18x8 215/40
Rear 18x9.5 245/35
Thanks,
Patrick
Note that different tires can have different fitments even if their size is the same - for example the Michelin PSS were a "square shoulder" tire so a 245 section looked like a 255 section from some other brands.
225/40/18 and 255/35/18 in the rear are much more readily available sizes and will fit your rims with no issue. Only thing to keep in mind is if your suspension is old and your shocks are worn you *may* have some rubbing given the tires are wider than what you have now and a teeny bit taller.
You have not listed your wheel offsets so it's hard to say/judge.
      03-22-2019, 08:28 AM   #3
chris_flies
Sideways and Smiling
chris_flies's Avatar
3027
Drives: In Exuberance
I'd stick with the 225/40 up front, and then move to a 265/35 in the rear. That said, I run square 245/45-17's on 17x7.5 wheels. It has a nice PHAT look to it...
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread
      03-22-2019, 08:59 AM   #4
Soterios
BXR
575
Drives: 2012 135i
So I just put a new set of wheels and tires on the car. The front set is an 18x8.5 that's flush with the fender. 235/40/r18 Nitto NT05. Rear is a 18x9.5 that's a bit sunk in (11mm or so) with a 265/35/r18 Nitto NT05.
I think they look great. I do get a bit of rubbing on significant bumps, but it's not bad, and I'm just going to have the fenders rolled. I'm currently on stock sport suspension. I do plan on dropping the car an inch on Eibach Pro Springs
I think a 225 up front and a 255 out would be fine if you don't want to mess with rubbing (depending on your offset)
2012 135i M Sport Alpine White
