03-08-2019, 06:05 AM | #1 |
330
Rep 984
Not sure if these are issues with the M3?
So I have a few issues that I think are not normal on the M3/M4 platform. I intend to take it to the dealer to have a check on it but sometimes dealers are liars and wont tell you the truth. Please correct me if im wrong and if any of these issues are actually normal
1. Door lock seems to be rattling. If I drive around with the car locked, the door rattles around the lock area. If I drive around with the car unlocked, the door does not rattle nowhere near as much as when its locked, maybe a slight rattle on the heaviest of imperfections and bumps. 2. The car makes a whining sound on low rpms which then disappears on higher rpm (around 2k rpm), is that supposed to be normal? Some people say its normal M differential whine. 3. Downshifts from 3rd to 2nd sometimes jerks violently when im lightly braking to a stop as if someone depresses a clutch and immediately releases it. Is that normal? 4. When I upshift quickly through the gears, 1st to 2nd, 2nd to 3rd are very smooth in upshifts but the 3rd to 4th gear upshifts when I don't lift my foot off the throttle and upshift manually in any of the throttle and drivelogic modes, feels quite jerky as if the car is doing a double upshift. Is that supposed to be normal? Thanks everyone! |
03-08-2019, 06:01 PM | #3 | |
Lost Motorcyclist
167
Rep 379
Cheers, |
03-10-2019, 06:35 AM | #4 |
182
Rep 357
Same as above. I'll add that even after a software update I can still trick the car into jerky stalling motion if I'm moving slowly in 3rd and I brake gently then go back on the throttle to move just a little further before braking again and it hesitates going into 2nd thinking I'm going to gas it....if I am more firm with my throttle and braking it won't. It's like when I'm hesitant it is too haha
03-10-2019, 11:12 PM | #6 | |
330
Rep 984
03-10-2019, 11:13 PM | #7 |
330
Rep 984
03-10-2019, 11:39 PM | #8 |
41
Rep 144
How does one check what software we are running...
I have a 'sometimes' quite jerky 3rd to 2nd slow low speed change also. Mid 2017 built LCI f82, 2018 complied. D |
03-10-2019, 11:48 PM | #9 |
182
Rep 357
If you get a USB key, go to the settings and profile screen in iDrive then export your profile to the USB key. Then put the key in a PC/Mac and open the folder and the text file in that folder from the USB key. Towards the top of the text is a version number of iStep.
SE7EN335330.00 |
03-11-2019, 04:40 AM | #10 | ||
182
Rep 357
04-07-2019, 08:19 AM | #11 |
330
Rep 984
Hey everyone, the dealer fixed the door lock rattles and also updated the whole car's software to March 2019 latest edition software. It has got rid of the jerkiness in 3rd to 2nd gear changes and the full throttle 3rd to 4th double upshift feeling as well. HOWEVER, I must say the latest software update has made the car feel like absolute trash in terms of torque delivery and responsiveness. It feels like turbo spool comes on at about 4k RPM now and I can see that the torque delivery is very linear like as if its a big NA v8 engine like the w204 c63s. Before I could full throttle in 2nd gear in sports plus and the car would push straight forward with good momentum, now it lugs for a good second then it gets going. Is there any way to get rid of this shitty torque delivery?
04-07-2019, 04:39 PM | #12 | |
182
Rep 357
Oh, to answer your question a throttle pedal adaptor (which alters the throttle position sensor output) would give you adjustment however you like and/or a remap. |
04-12-2019, 01:22 AM | #13 | |
330
Rep 984
But definitely after a few days the car is feeling more punchy now but not as punchy as it was before the update. |
mfurse182.00 |
04-12-2019, 08:28 AM | #14 | ||
182
Rep 357
Now when I'm pressing on its more in tune as a whole and flows better. You do need to give it more throttle but that's easily solved by mapping Sport/Sport+ as your M button preset. |
05-02-2019, 03:11 AM | #15 |
330
Rep 984
Does anyone know if a groaning sound from the LSD on a 2nd gear crawl in very low speeds (like parking lot speeds) is considered "normal"?
The dealership says its making a bit of noise but is classified as normal wear and tear for a 2016 M3 with 55k kms which I find a bit hard to believe. |
