Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      02-25-2019, 11:02 PM   #1
Sassriverrat
22
Drives: M4
2015 BMW M4  [0.00]
Easy Access Seats with ignition
Hello Again-
OK playing with settings-
My driver's seat is working nearly perfectly for easy access- one hiccup-
When I get out, the seat goes back just as it should. However, when I close the door it moves forward again- this is- independent of whether I'm actually sitting in the car or not. So this movement is entirely based on the door opening/closing, not ignition. If I get out (seat is back), close the door (seat moves forward), then go to reopen the door, the seat doesn't come back- it's in the driving position until the car is turned off again.
How do I make it stay in the "easy access" position until I restart the car?
Thanks
      02-26-2019, 11:39 AM   #2
backagain
just a fool
backagain's Avatar
China
345
Drives: 2016 SO coded M3
The seat shouldn't move the 2nd time.
My get-out sequence is: ignition off, open door, seat moves back, get out, close door (seat doesn't move a 2nd time.)
Get-in sequence: open door, get in, ignition, close door, seat moves forward, drive off.
So sounds like you've inadvertently changed some values to result in this behavior. Suggest you get all parameters back to the published values.
      02-26-2019, 10:09 PM   #3
Sassriverrat
22
Drives: M4
2015 BMW M4  [0.00]
that's what I figured as well. I was hoping someone might have known right away what parameter I might have set that could do this so I could quickly change it.
      03-03-2019, 09:35 PM   #4
Roch M4
I /// M FAN
424
Drives: M4 SS/SO 2016 / X5M C 2023
I noticed that the seat sensor related to airbag activation and seat belt reminder is also connected to the seat movement. When you close the door without engine on or ignition, if you get of the seat without opening the door, the seat goes back. Also after turning off the engine, you open the door, the seat goes back...but if put your hand on the seat with some pressure or weight..after closting the door, the seat will move forward even if you are not seated after closing the car..
      03-03-2019, 11:23 PM   #5
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
you must change as shown below
SM2 -> 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV
SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28
SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C
      03-04-2019, 10:22 AM   #6
B335T M0DE
Drives: '17 ZCP M4
Can I do this with Bimmercode?
      03-18-2019, 02:19 AM   #7
88tuning.id
88tuning.id's Avatar
Indonesia
39
Drives: E39 520i Msport
Of course, you can do it on expert mode.
or i can do it remotely for you.
      03-18-2019, 01:31 PM   #8
Sassriverrat
22
Drives: M4
2015 BMW M4  [0.00]
I must have tweaked something extra because my seat moves every time the door opens and closes- irregardless of ignition. All of my settings match the above. Would "comfort" options mess with this?
ALP
      03-19-2019, 09:05 PM   #9
88tuning.id
Indonesia
39
ALP
what "comfort" options do you mean?
T
      03-21-2019, 03:00 AM   #10
Sassriverrat
22
Drives: M4
2015 BMW M4  [0.00]
i remember seeing a "comfort" piece in one of the modules. I'm currently on a ship and won't be back till May. Is there a way, using my saved files, to be able to open the modules within Esys (as if I wanted to simulate coding)?
      03-23-2019, 06:38 AM   #11
88tuning.id
Indonesia
39
Unfortunately esys can only open list of generated SVTs, but once you want to access the CAFD, you will need to connect your laptop to your car
Instagram: @tafikhulafaa & @88tuning.id
f80post
