02-24-2019, 10:19 PM | #1 |
660
Rep 120
Easy DIY license plate holder by Sto N Sho. It's removable and quick-release.
I like the centered look as opposed to using the tow hook location. It only requires you to drill 1 hole for the bracket. The hole is made on the underside so it is not visible if you remove bracket in the future. The bracket itself is barely noticeable. I'm in New York, so front plate is required. This holder has a cleaner look and does not put holes on the front of your bumper. However, I usually leave my front plate off most of the time. I bought this on Amazon. You can use any plate frame (not included) or go frameless, for an even cleaner look. Last edited by EricU; 02-24-2019 at 10:26 PM.. |
02-25-2019, 08:40 AM | #3 |
166
Rep 710
i just used zip ties to put mine on the grate right below that. hasnt hurt cooling as i am not tracking the vehicle.
looks slightly cleaner imo but may fit everyones aesthetic or local laws (it is set back a little) |
