Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      02-20-2019, 08:55 PM   #1
Deleted-User
Drives: N/A
DIY How to perform iSTEP UPDATES on NBTEVO (for enabling fullscreen CarPlay)
In order to enable fullscreen CarPlay via a 3rd party .BIN solution, you need to be running on [18-07-549 / NBTevo_O] or greater. For reference, my MY2018 F80 was running [iSTEP 17-07-507 / NBTEvo_L].
This PDF covers the entire process of how to update your NBTevo headunit. Fully documented with photos, screenshots and even a process log so you can follow step by step. This same guide can technically be used to update any module in your car --as always, do your research as your conditions may differ than mine. You assume all responsibility and risk. This guide is for educational purposes only.
Please PM me if you have any feedback.
Appreciate 8
jbed39.50
yjypm219.00
DrifterX514.00
rakusak134.00
IK6SPEED4490.00
BMWMPR76.50
T4RUSAF49.50
      02-24-2019, 08:44 PM   #2
pmooiweer
Zymurgist
pmooiweer's Avatar
Drives: 2018 BMW M3 (F80)
Thanks for sharing this. I'm looking at buying the full screen patch by itself, which requires CarPlay to be installed and activated. I was hoping that flashing HU_NBT2 wouldn't require reactivating CarPlay, but I guess that's not the case. Does CarPlay need to be reinstalled or reactivated after flashing and, if so, how do you do that (where would I get the .bin file needed)?
bordins145.00
      02-24-2019, 09:04 PM   #3
Deleted-User
Drives: N/A
Just sent you a PM.
      03-19-2019, 01:55 AM   #4
sj22
197
Drives: 14 F15 50I
thanks for this, i will upgrade atm and nbthu2 isteps for full screen carplay this weekend. how long did the update take for you? any idea how to activate full screen carplay using fsc since the bin method wont work with the latest isteps?
      03-19-2019, 12:00 PM   #5
Deleted-User
Drives: N/A
Took about 45 min. If you check the log at the end of my document, it gives you a full timeline as to how long each section takes.
Also, hit up wibbles for fullscreen activation with the latest istep.
      05-03-2019, 10:22 AM   #6
ssgm1x
ssgm1x's Avatar
419
Drives: 2020 M340i & 2018 M3
DO NOT DO IT !!!! Updated my 2018 M3 NBTevo to latest software (just the NBTevo was updated) then patched fullscreen carplay. iDrive unit keeps rebooting now 1-3 times a day. Its not worth it .....
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      05-05-2019, 04:10 PM   #7
Deleted-User
Drives: N/A
I've done this procedure on two different 2018 M3, including a M3 CS and I have not experienced any kind of rebooting, bugs, lags or glitches of any kind.
      05-09-2019, 09:05 AM   #8
pmooiweer
Zymurgist
pmooiweer's Avatar
Same here; no issues whatsoever. I flashed NBT to version P (November 2018 software version) and patched CarPlay via Enet cable/internet.
      06-09-2019, 04:48 PM   #9
i4M50Guy
i4M50Guy's Avatar
88
Drives: M140i
Do you need to use ISTA to clear any errors or is ESYS all that's needed?
      06-10-2019, 05:17 PM   #10
pmooiweer
Zymurgist
pmooiweer's Avatar
I used ISTA to clear all errors, both before and after flashing (so I could tell which errors were specific to NBT flash). Note that flashing takes about 45 minutes, so make sure to use a power supply to avoid draining your battery.
The full-screen patch takes about 6 minutes and requires a strong internet signal. Assuming you'll be using your wired port for connecting to the car, you'll need a strong wireless internet connection.
      12-06-2019, 01:45 AM   #11
PaulM4
PaulM4's Avatar
12
Drives: 2016 M4
Hi folks. I'm looking for updates my ISTEP to the latest but I have Head unit retrofitted to ID6 will it be any issue?
      12-06-2019, 01:39 PM   #12
kubax86
BimmerPost Supporting Vendor
kubax86's Avatar
1790
Drives: M2
You need to have OABR(Ethernet to Gateway) connected.
      05-19-2020, 10:42 AM   #13
sstyle
13
Drives: X3MC F97
But how to know shipment I-step if I retorit HU?
      05-20-2020, 01:37 PM   #14
cryptz
Drives: 2015 m4
just wanted to throw it out there, i have found that to not be overly critical. if you calculate everything and the hwel is black it will update without issue. I tested mine and found a handfull of istep shipment versions that all resulte din hwel being black. its possible there were no nbt evo updates through those various istep shipment builds, or perhaps it isnt that sensitive. Either way my evo came from a 2019 car, every istep shipment variation i tried from late 2018 had the same result.
      08-12-2020, 07:37 AM   #15
nbt
nbt's Avatar
Germany
-1
Drives: 2016 f36 430i MPacket
Hi all
I have esys 3.30.1 with v.4.24.31_PSdZData_Lite.rar
This is what i use for Coding.
Now i want to do the iStep for my NBTevo ID4 to ID6 and to install carplay.
i saw that there are 2 versions of FULL PSdZData:
For i.e:
v.4.23.12_PSdZData_Full and v.63.3_PSdZData_Full
What are the diferences between the 2? which one to use for the flashing from id4 to id6?
do anyone have a guide to do this?
Thanks!
      08-12-2020, 10:24 AM   #16
kubax86
kubax86's Avatar
1790
Drives: M2
They are different versions.
After flash you would need to get Full FSC PACK to activate all features as well as proper coding.
Thanks
      08-31-2020, 06:38 AM   #17
byvlad
Drives: BMW 540xi G30
Somebody knows how to avoid ATM flsl error?
Because EVO is retrofitted and I don't have ATM in my car.
      09-05-2020, 10:18 AM   #18
deneyer
Belgium
35
Drives: BMW
PDF link is death, can you replace it please? Thanks
      01-29-2021, 09:41 AM   #19
Shay1128
Shay1128's Avatar
Drives: BMW 330xi, X1 (pre-LCI)
Link of PDF is not working. Can you re upload it?
      01-29-2021, 07:57 PM   #20
D3LM3L
Drives: 2016 BMW M3
Is it possible to flash the NBTevo with the engine running? Or does the car have to be in run mode and connected to a power supply?
      01-30-2021, 04:10 AM   #21
kubax86
kubax86's Avatar
1790
Drives: M2
Not possible with engine running.
Thanks
TopJimmy5461.50
      01-31-2021, 08:55 PM   #22
D3LM3L
Drives: 2016 BMW M3
Thanks
OK, thanks, and is it possible to hook up the car using jump leads to another one that's running, and use the second car as a power supply?
Tags
carplay, diy, e-sys, istep
f80post
