BMW M3 Forum (E90 E92)
BPM
      02-20-2019, 10:20 AM   #1
TomHudson
658
Drives: 2011 E90 M3
Clunking noise e90 m3
To begin with, I Just replaced sway bar bushings, front control arms are ok..
Clunking noise over bumps, but goes away when the EDC setting is on sport.
Any ideas? Any experience with this?
Please help!
      02-20-2019, 10:47 AM   #2
BayE30
Drives: 2011.75 E90 M3 ZCP
did you properly preload the sway bar bushings before you tightened down the bushing bracket?
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      02-20-2019, 04:41 PM   #3
TomHudson
658
Drives: 2011 E90 M3
The bushings were installed at a very reputable Indy garage, but I will follow up.
I’m wondering about either the EDC shocks themselves, or the shock mounts.
It’s very unusual to have the noise disappear under sport plus. The sway bar bushings would make noise either way...
      02-20-2019, 09:19 PM   #4
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
I'm wondering about either the EDC shocks themselves, or the shock mounts.
It's very unusual to have the noise disappear under sport plus. The sway bar bushings would make noise either way...
I had a similar issue when my shocks went bad. The mounts were bad ass well.
2014 M5 6MT
      02-20-2019, 10:07 PM   #5
E90M3velocity
Philippines
338
Drives: Manual-Slicktop E90 M3
Check the steering rack bolts, some do get loose
      02-21-2019, 06:22 AM   #6
TomHudson
658
Drives: 2011 E90 M3
Thx.
I’m leaning towards pulling shocks out, and replacing them as well as with new mounts.
Anyway of visually inspecting that EDC shocks are bad? They still function, but I wouldn’t want to replace them if they’re still good.
      03-22-2019, 07:39 PM   #7
JayR_e92
JayR_e92's Avatar
239
Drives: '08 6MT e92 M3.
Thx.
Not sure if you are still having issue as it is now March. I literally just had a similar issue last week after getting some suspension work done.
It turned out to just be my Left Front Lower Ball joint NUT was loose!
They tightened it up as well as all the nuts in its vicinity and it completely went away.
Anyway, not sure if we had the same issue but I figured i'd that just in case!
      03-23-2019, 07:59 AM   #8
TomHudson
658
Drives: 2011 E90 M3
Thanks.
With the weather warmed up, I’m leaving the car at my Indi for a few days.
They’ll sort it all out, and I’ll let you know.
      04-11-2019, 08:57 PM   #9
youngstatic
Drives: ZCP E92 M3 Alpine White
t
      04-13-2019, 02:22 PM   #10
TomHudson
658
Drives: 2011 E90 M3
Replaced sway bar and bushings, all good.
      04-13-2019, 09:18 PM   #11
E90M3velocity
Philippines
338
How many miles on the swaybar bushings?
      04-14-2019, 10:12 AM   #12
TomHudson
658
Drives: 2011 E90 M3
I’m not sure what you mean?
I replaced the bushings on the aftermarket bar and they proceeded to get chewed up.
Went back to stock sway bar and all is good.
      04-14-2019, 10:15 PM   #13
E90M3velocity
Philippines
338
Just wondering if the wear from high mileage caused the worn bushings
      04-14-2019, 10:37 PM   #14
pbonsalb
5234
Replaced bushings or endlinks? If links, were you using stock or adjustable and were they the correct length for the aftermarket swaybar?
      04-15-2019, 07:15 AM   #15
TomHudson
658
Drives: 2011 E90 M3
That’s a good question!
While the car was supposed to have stage 3 Dinan, I believe over time the previous owner replaced worn parts with different aftermarket or stock.
The garage owner took his time with my car this time and the cure was to replace the sway bar with stock.
I as tempted to go back to Dinan, but for the driving I do, this will be fine.
I am certainly just happy to have the clunk gone!
Now, of course, I still have brand new bilsteins b6 EDC...
      04-15-2019, 07:16 AM   #16
TomHudson
658
Drives: 2011 E90 M3
I replaced the bushings not that long ago (months) and they were chewed uporetty damn quick. Either wrong size or some other issue..
m3post
