02-10-2019, 04:30 PM | #1 |
Rep 55
I've had a problem for couple weeks with iPhone apps that deliver voice notifications or alerts via Bluetooth HFP, and namely with Waze and V1Driver (an app that provides GPS functionality and voice alerts to a Valentine One radar detector). I am using iOS 12.2 beta, which most likely is the culprit. I thought I would ask here to see if anyone else has encountered similar problems and perhaps has found a solution.
Bluetooth calling works fine using HFP. When streaming audio from my iPhone, I hear voice alerts form Waze and V1Driver. When talking on the phone using HFP, I hear notifications. But when I'm listing to Sirius or the radio, and Waze or V1Driver sends an alert, the iPhone connects via BT HFP and interrupts the audio, but I don't hear any voice message. Instead I get silence for a few seconds. The telephone volume is not off, and iPhone notifications are on. I've deleted to BT connection and re-paired a couple of times, bit that hasn't helped. I'm guessing that Apple changed the BT stack in some fashion and HFP isn't working properly with iDrive and my X5. Has anyone encountered similar issues? Maybe there is a workaround or fix? Thanks. |
02-10-2019, 07:12 PM | #2 | |
197
Rep 535
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
02-10-2019, 07:16 PM | #3 | ||
Rep 55
02-10-2019, 09:36 PM | #4 |
197
Rep 535
Ok so I have seen this happen when USB is connected and call comes on BT. I have the latest iOS and no issues if I don’t connect usb. I also updated the software on the car so that’s another thing to try if it keeps happening.
02-11-2019, 09:27 AM | #5 | |
7533
Rep 1,247
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
I don't have i stuff, so not the same - but I used the long press on the HFP button a LOT to use Google assistant. When I first got the car I would do it and here the beep telling me to start. Now for some reason I do not. It still works and I just have to guess when to speak, but it is like there is a 3-5 second delay before I can hear the responses after I switch from anything else to HFP. Like you said - when I stream via bluetooth and trigger it - it works fine (because there is no change over). Kinda sounds like the same thing you are speaking of, but not sure.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
02-11-2019, 08:12 PM | #6 | ||
Rep 55
02-11-2019, 09:40 PM | #7 | |||
241
Rep 307
