KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
07-21-2008, 02:05 PM | #1 |
597
Rep 5,448
track tire report - WOW! impressed with the BFG R1 tires at the track
I have 265's all the way around on 18x9 rims. I drove up to Buttonwillow on the tires. first off they are loud, bumpy, and make the car twitchy and very nervous on the street. EDC on comfort for sure. but on the track these tires come alive and all that goes away. they are precise. they are confidence inspiring. they are awesome. they stick really well. they dont overheat. they are very consistent and they wear very evenly. It was VERY hot there -about 105 degrees. pavement temps were literally scorching. but tire temps were in the 165 range (160 to 200 recommended) and very consistent across the tire within 10 degrees (25 recommended). Due to the heat I was fighting to keep tire pressures at or below 48 psi (recommended 34 to 48). I ended up running 47f/48r hot. big thumbs up to BFG (owned by Michelin) and Tire Rack.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
07-21-2008, 04:42 PM | #2 |
M3Post Supporting Vendor
87
Rep 964
Very nice! I am glad to hear that they are working out so well. The R1 is definitely a beast on the track, although as you mentioned, they are not much good on the street, and really are intended to be put on at the track. (Obviously you did ok driving to the track, just don't get caught in the rain, and stay away from potholes. )
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
07-21-2008, 11:48 PM | #4 | |
597
Rep 5,448
07-21-2008, 11:52 PM | #5 |
127
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
I can't wait to try them out myself. What wheels are you running on the track?
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
07-22-2008, 03:08 PM | #7 |
597
Rep 5,448
no pics of wear yet - had four hard sessions on them and the wear is visually non-existant. they just look nicely scrubbed in.
the wheels are the tire rack TRmotorsports 9x18. love them - really light too. 5mm spacer in back just to get the track a bit wider. since it was soooo hot I was bleeding of air after every seesion to keep below 48 as this is the max recommended by BFG. if the weather was cooler I would have tried closer to low 40's. however tire temps were good and consistant across the tire. the tires did not feel greasy. when I left the track I had 47/48 hot. the next morning while cool they were at 30. 18 psi drop!!! camber/suspension is stock pics as new BFG info: http://www.tirerack.com/images/tires...ce_R1_care.pdf
07-23-2008, 01:08 AM | #8 |
52
Rep 648
Great!
I have bled down the air at the track to around 40 on hot days and have ended up the next morning at 24-28 cold! Similar results as you. I now start at 30 cold to start. |
07-23-2008, 08:11 AM | #9 |
156
Rep 1,429
So I'm guessing the square setup worked out? I know E46s favored a square setup, and was interested to see how the E9xs like it.
07-23-2008, 11:12 AM | #10 |
817
Rep 7,887
I do not know how he would be able to know the handling balance as he was running with the MDM on.The MDM will reign the car in long before any real slip angles will happen.
07-23-2008, 11:25 AM | #11 | |
597
Rep 5,448
next track day I will turn MDM off.
07-23-2008, 02:27 PM | #12 |
374
Rep 8,033
I recommend not pushing the PS2s on the track. Mine are pretty abused after 3 days on a tight track which requires heavy breaking, and the fronts are worn somewhat evenly in the middle. Also, the car's pulling to the left just slightly, and I am betting that there is nothing wrong with the alignment. Had my service guy check it out, he also thinks it's tire wear related. I'm thinking about a track setup as well...
07-23-2008, 11:59 PM | #13 | |
597
Rep 5,448
exactly one of the reasons I got track tires. the track tires handle the heat better - street tires overheat, chunk and wear out faster on the track. and they aint cheap.
07-25-2008, 11:55 AM | #15 | |
12
Rep 306
The cars are on stock 18s with PS2s. They also admitted that they don't use stock pads, although in September they said stock pads; their track pads are RIDICULOUSLY noisy. Side note: The PS2s have great feedback from the road when you come in hard in a corner, so you can avoid understeer easily even if push too hard. |
07-26-2008, 02:34 PM | #16 |
597
Rep 5,448
no problems at all. even tho it was hot BW is not too hard on brakes. Cal SPeedway in Sept will be the real test. it has two hard braking zones from over ~140 mph in a row. hopefully the weather will be cooler
07-26-2008, 04:06 PM | #17 |
156
Rep 1,429
VIR has two braking zones from ~140 too. The brakes held up fine for me.
07-26-2008, 11:52 PM | #18 | |
597
Rep 5,448
Laguna Seca is hard on brakes too. but its not currently on my schedule. maybe next year.
07-27-2008, 02:12 PM | #19 |
41
Rep 644
I took my wheels off the other day to clean them....I was surprised at how small the actual brake pad is......in terms of surface area..... Smaller than I would have thought for a 14" brake......
Brian
2008 E92 M3, MR, DCT, extended BB leather, loaded! 1988 Porsche 928S4, Guards red/Champagne leather 1989 Porsche 928S4 track beast!!! |
07-28-2008, 09:16 PM | #20 | |
597
Rep 5,448
like they say its not always the size that counts.....
08-01-2008, 07:40 PM | #21 | |
148
Rep 2,278
2015 f80 M3, 2016 GT3
08-02-2008, 10:16 AM | #22 |
597
Rep 5,448
track tires FTW!
