02-02-2019, 10:34 PM | #1 |
390
Rep 659
Intake Pipe, screw went into the pipe...?
Hello
I was about to install the charge pipe and After I was trying to unscrew the bolt from intake pipe, i dropped the 10mm into the intake pipe... oh my.... what do I do?? Any advice?? Thank you! Last edited by M3nmotion18; 02-02-2019 at 10:59 PM.. |
02-03-2019, 02:13 AM | #2 |
209
Rep 314
Don't panic... a magnetic with an extension will easily retrieve the 10mm bolt, ask for it at your local automotive store.....you will get it
M3nmotion18390.00 |
02-03-2019, 01:51 PM | #7 | |
390
Rep 659
After I got the 10mm out of the Intake pipe, when I tried to tighten the charge pipe, I dropped the OEM screws underneath somewhere and I can't find with my extension magnetic... I guess I need to remove the undertray to find that bolt... |
02-04-2019, 05:20 AM | #8 |
209
Rep 314
Its a bitch....removing all that strut assembly to access the front plugs...invest in a good torque wrench ( digital and accurate )....and I HAD TO ORDER the freakin spark plug socket from amazon!!!! no local parts store had shit napa, autozone or sears craftsman tools...other sockets came close to fitting but i would have damaged the threads or worse because the heads are aluminum... be careful. definitely have to be patient doing this ..but its 750 at the dealer and most shops
M3nmotion18390.00 |
02-04-2019, 05:25 AM | #9 | |
209
Rep 314
02-04-2019, 12:13 PM | #10 | |
390
Rep 659
Thank you!! |
02-05-2019, 08:54 PM | #11 |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
I would purchase an OEM replacement instead. That way you are insured it is the correct length and grade. Shouldn't cost much.
/// M3 |
M3nmotion18390.00 |
02-05-2019, 09:38 PM | #12 | |
390
Rep 659
Thanks! |
02-05-2019, 10:00 PM | #13 |
3274
Rep 6,723
You shouldn’t need to replace the push rivets unless you damage them when removing. The head of the rivet is designed to slip up and will remove the pin under the head to release its expansion of the surrounding sleeve.
M3nmotion18390.00 |
02-05-2019, 11:15 PM | #14 | |
390
Rep 659
Thank you! |
