01-21-2019, 03:19 AM | #1 |
13
Rep 52
Cold start delete... negatives?
Any harmful mechanical problems or long-term issues with having cold start flashed completely off? Stock dp/cats
01-21-2019, 03:31 AM | #2 |
42
Rep 62
Drives: '64 BMW F83 M4 Convertible
Big Negative... You don't get to annoy your neighbours anymore
schnell325889.50 Tall Tom Cruise1001.50 |
01-21-2019, 10:38 AM | #3 |
Rep 39
I thought the purpose of cold start is to warm up the cats faster, so they can properly clean the exhaust gas. I think the only negative is that you will be more harmful to the environment before the cats get to proper op temp?
01-21-2019, 12:18 PM | #4 |
227
Rep 369
Correct. The substrate material in the cat’s need to be warm to be effective. Cold start is simply a higher idle (and depending on the car, activation of a secondary air injection system) to warm up the cats. If you install catless downpipes, there is no reason to have the feature at all.
///M3
01-21-2019, 02:19 PM | #6 |
4998
Rep 6,863
ClearMinded7.50 |
01-21-2019, 08:43 PM | #8 |
13
Rep 52
So if I have stock downpipes... main issues are it'll have less clean exhaust gases the first few minutes after start and since I have DCT it'll be not as smooth to drive until it warms up a bit? Does BMW's recommendation to drive off right after cold starting still apply after cold start sequence delete or would idling a minute or so after start be beneficial now?
01-21-2019, 10:12 PM | #9 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
You might hear a clicking noise until warmed up near top passenger side of motor from some activator gizmo people seem to be bothered by.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
8_is_enough197.00 NBGV18.00 |
01-21-2019, 10:38 PM | #10 |
46
Rep 211
This is good to know. I always thought it was the valve actuation that defined cold start!
01-21-2019, 11:20 PM | #11 |
793
Rep 1,627
I deleted cold start via BM3 for approx 5,000 miles. I liked the quieter start up better for sure, but smelled gas fumes during cold idling (akin to having cat delete) and the clicking noise from the front passenger side of the car when cold was annoying. So I decided I'd rather annoy my neighbors than myself and turned it back on; they have kids after all, so I figure my car with valves open and cold start activated makes us more than square.
M4 in MG | 6 MT
01-23-2019, 01:42 AM | #12 | |
252
Rep 674
jd__m4414.50 |
01-23-2019, 03:03 PM | #13 |
3072
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
that’s a derogatory term. i believe you meant timing is intellectually and developmentally disabled.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
01-23-2019, 03:41 PM | #14 |
252
Rep 674
