01-20-2019, 02:47 PM | #1 |
Mr Bill
296
Rep 545
Race Seat Coding
Has anyone figured out how to get rid of the errors and not plug in the factory seat buckles. I've coded out the airbags, etc... but I can't get the restraint malfunction to go away unless I plug in the seat belt buckle connector.
These are all coded and seem to work. Occupancy sensor: CIS_Beifaher: aktiv -> nicht_aktiv Driver seat airbag: Sitzairbag_Thorax_Fahrer: aktiv -> nicht_aktiv Passenger seat airbag: Sitzairbag_Thorax_Beifahrer: aktiv -> nicht_aktiv Passenger seat position sensor: Sitzpositionsensor_Beifahrer: aktiv -> nicht_aktiv Driver seat position sensor memory: Sitzpositionsensorserkennung_Sitzmemory_Fahrer: aktiv -> nicht_aktiv
2018 GLC63
2016 Miata 2020 X3M (sold) Turbo Miata Racecar (sold) 1995, 2009, 2015 M3 (sold) |
01-20-2019, 04:09 PM | #2 |
Mr Bill
296
Rep 545
Got it.
Code the following Gurtstrammer_Fahrer ->nicht_aktiv (belt tensioner driver driver) Gurtstrammer_Beifahrer ->nicht_aktiv (belt tensioner driver passenger) Gurtkontakt_Fahrer ->nicht_aktiv (belt contact driver driver) Gurtkontakt_Beifahrer ->nicht_aktiv (belt contact driver passenger) Gurtzustandsanzeige_Fahrer_GWF_GZA_FA ->nicht_aktiv (Belt condition indicator driver driver) Gurtzustandsanzeige_Beifahrer_GWF_GZA_BF ->nicht_aktiv (Belt condition indicator driver - passenger) Abschalten_Fehlerqualifikation_Plausipruefung_dyn_ Daten_FGS->nicht_aktiv (Shutdown Error qualification Plausibility error)
2018 GLC63
lavon2.00 Clevocapri18.50 |
01-27-2019, 03:19 PM | #4 |
Mr Bill
296
Rep 545
It's in post 1
2018 GLC63
04-03-2020, 07:32 AM | #9 | |
Rep 12
04-24-2020, 02:36 PM | #10 |
69
Rep 116
05-09-2020, 10:52 PM | #12 |
93
Rep 76
I tried to install the seats in an 2020 F87 M2 Comp today, and seems like no matter what I do, I can't code out one restraint system error.
I only have the driver seat changed right now, was making sure I can code everything before changing the passenger seat. I have the factory belt buckle on, the connector is connected correctly, because if I remove the connector I get a secondary code. I tried to clear all the codes with tool32 but one won't clear. So far I coded all the following: Occupancy sensor: CIS_Beifaher: aktiv -> nicht_aktiv Driver seat airbag: Sitzairbag_Thorax_Fahrer: aktiv -> nicht_aktiv Driver seat position sensor memory: Sitzpositionsensorserkennung_Sitzmemory_Fahrer: aktiv -> nicht_aktiv Coded all the memory settings to nicht_aktiv as well. I even tried what bracer posted, but never was able to get rid of this last restraint error. Any help would be appreciated. |
05-10-2020, 04:09 PM | #14 |
93
Rep 76
Yeah I did.
So I hope this post helps someone in the same situation in the future. I have seen a few people with similar problems to what I was having trying to find a solution. No matter what was coded as "Nicht Aktiv" there would still be one error for a restraint system, even with the seat belt buckle connector plugged in correctly. Also Tool32 would not be able to erase it. I coded the car back to factory coding then coded out the same things that was discussed in this thread, cleared the existing codes that popped up with tool32, voila, magically no more errors. |
05-10-2020, 06:01 PM | #15 |
Mr Bill
296
Rep 545
Ah yes, you had a latched fault that needed to be cleared. You could have used ISTA to clear it I bet.
2018 GLC63
05-10-2020, 10:09 PM | #16 |
93
Rep 76
07-07-2020, 07:18 PM | #17 |
13
Rep 96
Sorry if this is a dumb question. Does the steering wheel and front pass airbags still go off in a collision if the codes above are executed? Thanks all!
Currently Driving:
Porsche GT4 '20 BMW M2C '19 Caterham S3 '01 Porsche 993 '96 |
01-04-2021, 06:40 PM | #19 |
432
Rep 938
Hey Guys, i have a 2016 M3, if i buy these seats, will i be able to code out all the dash lights but still keep my air bags functioning?
I'm looking at doing driver and passenger so i can run harnesses for the track. https://www.vividracing.com/recaro-s...152634569.html
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
02-04-2021, 03:34 AM | #20 | |
Rep 8
Anyone else shine any light on this I tried all the above parameters plus more but having this issue - F87 M2 Competition |
02-04-2021, 08:09 AM | #22 |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
Assuming all of the coding from above is correct, did you try using ISTA to clear any air bag/restraint faults? Tool32 was mentioned above for fault clearing purposes. I am not an expert on Tool32, but I do know it is an older BMW diagnostic tool as ISTA is the current BMW dealer diagnostic tool of record. Since the F87 is a very new'ish BMW, Tool32 may not be working properly for the F87 due to the age of the tool.
If that is not the case (i.e. ISTA could not clear the fault), then there could be some software/coding differences between the F87 and the F80/82. Despite the obvious similarities between the M2 and the M3/M4, this would not be the first time there is a software/coding difference that causes issues like this. If all else fails, you may need to hit up a paid coder as there are still some coding "trade secrets" they keep to themselves.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
