KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
07-17-2008, 10:26 PM | #1 |
162
Rep 621
Drives: 18’c63s,15’macanturbo,14’ 991s
flat tire warning
So i am driving to work today and the warning comes up saying you have a flat
tire. I was only about 5 minutes from work and the car felt fine so I didn't pull over. When I got to work I looked at the tires and they seemed to be ok. I reset the tpms and drove home carefully. When I got home I tested the psi. 41 in the front and 43 in the back. I checked the manual and it says 33/35. So either my tire pressure gauge is off or my dealer is retarded. Anyways the warning hasn't come up again so hopefully its was just a false alarm. What pressure do you guys keep your e92 at? thanks lebreeze
07-17-2008, 10:32 PM | #2 |
374
Rep 8,033
If you are using the stock tires, I'd stick to the specified cold pressures for everyday driving. Pressure will increase when you heat up the tires, but I doubt that you pushed the car hard enough on your way home for them to get up to 41/43.
10-30-2010, 07:49 PM | #3 | |
11
Rep 144
2010 jzb e92
11-03-2010, 09:56 PM | #4 |
62
Rep 764
That's funny, mine came on yesterday haha. All my tires appear fine visually but I haven't had time to check pressures. I'm hoping it was due to the sudden cold weather. Went from a steady 60 degrees to sub 40 in the mornings.
11-04-2010, 09:12 AM | #5 |
86
Rep 2,148
I had the same issue a couple of days ago. All four tires had low pressure. I used the tire gauge and had 20 psi all around. Filled it back up to 33/35 and the warning sign disappeared. Checked the pressure again after a 30 min drive and it was okay. I'm assuming these PS2 tires are very sensitive to temp changes. I wonder if Conti's do the same.
11-05-2010, 06:56 PM | #6 |
17
Rep 246
I get that message once in a while also. Its my experience that all low profile tires leak air, especially in the cold. Keep them 1lb over factory setting, check every month or month and a half and keep a 9/16 deep socket in car, sometimes TMS sensor gets loose and leaks real slow. Snug them up, dont over-tighten or you will crack them.
