Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      01-13-2019, 05:33 PM   #1
MetZF82
64
Drives: 2015 F06 M6
Limp mode
So I just went into a limp mode. Using the jb4 Bluetooth code reader these are the codes that came up.
Anyone experience these fault codes? I can't find anything when I try searching.
      01-13-2019, 06:03 PM   #2
xsb00st
Drives: Slow
121101 - Charge pressure sensor 2, electrical: Short circuit to positive
120908 - Charging pressure control2: Switch-off, pressure build-up blocked
Check your tmap sensors
      01-14-2019, 09:39 AM   #3
MetZF82
64
Drives: 2015 F06 M6
Thanks a lot. When I put it in map 0 the car works fine. In stock form.
I'm gonna see what happens today when I try to put it back into map 1.
      11-28-2020, 04:21 PM   #4
aann
24
Drives: f13 M6 2016
Did manage to solve the problem ?
      11-29-2020, 12:01 AM   #5
Spacecpe
44
Drives: E90 335i Msport
Sounds like the tmap is unplugged or loose.
      12-02-2020, 11:17 AM   #6
MetZF82
64
Drives: 2015 F06 M6
I thought I commented. Somehow water damaged the jb4 module. There was massive corrosion all over it.
I removed the jb4 and it worked np. Burger tuning hooked it up with no issue though.
Told them what happen. I shipped it over. They shipped it right back. Always great customer service with those guys.
6post.com
