01-12-2019, 08:28 AM | #1 |
Rep 21
OBD cable stuck
So I reflash to the latest version of BM3 and try to remove the cable and it won't budge. I'm putting some serious force into pulling this thing out with no luck. Any tips I've been driving around with this cord all morning.
01-12-2019, 10:41 AM | #4 |
237
Rep 255
OBD cable stuck
The cable I purchased got stuck to. It had a whole were the notch is supposed to be. I had to use a screw driver with tape on the end to prevent damaging the OBD port. It took me couple days to get it off. The cable should have a covered notch to allow you to remove it easily.
lilpump2.50 EosDigital3.00 |
01-12-2019, 04:54 PM | #5 |
Rep 21
Got the f***ing thing off I've been at it all day. 20 seconds with the blow dryer and it popped right off. Removed the little plastic piece that it got caught on.
01-12-2019, 07:00 PM | #6 | |
237
Rep 255
The cable on the left had the whole in it and I had to break the plastic piece to get it off. I bought a new one on the right that has the entire whole covered. |
01-13-2019, 09:18 AM | #7 |
169
Rep 1,039
01-13-2019, 10:40 AM | #8 |
Rep 21
Yeah I would break it off. It's still a snug fit so it won't just fall out.
01-13-2019, 10:46 AM | #9 | ||
Rep 21
12-17-2022, 10:04 PM | #10 |
Rep 28
By the time I found this thread, my obd cable was also stuck. In the event someone finds themselves in the same situation (where the plastic piece that holds the cables onto the interface has not been cut off), I was able to remove the cable by repeatedly rotating it towards the front and the back of the car while pulling down.
I had to use more force than I wanted, but I wasn't able to pry it off by wedging a small screwdriver between a nub on the car's port that the cable locks onto and the opening of the cable. Like the posts above, I was able to easily attach and remove that same cable once I cut the plastic piece that was securing the cable to the odb port. |
