01-10-2019, 11:45 PM | #1 |
Love2speed
42
Rep 55
Drives: 2019 M4 Conv. zcp 6M
2nd Cat delete but keeping the look specifically for California
Hi Folks,
just wanted to share a different method for the 2nd cat delete. This method removes the Catalytic core only and should pass the visual inspection especially for California SMOG tests. I was surprise how easy and clean it was. Background: The sound of my zcp exhaust is good but wanted it to be a bit louder while maintaining the ability to be quiet when needed. I bought a 2nd set of zcp exhaust from a member in this forum and experimented on it just in case I royally screw things up, I would still have my original to go back to. The mod: I notice from day 1 these catalytic were 2 halves welded together with a huge seam tab. I started with a grinder and ground about 3mm off the seams on both sides. I then cut only the top half of the shell and the Ceramic core literally rolled right out. The core is held in by some heat insulation shield which came off easily too. It took about 3 hours to remove and Tig weld it all back together. Because I had only cut the top half, I did not have to re-align the tubes between the mid section to the flange pipe as everything was still held together. It was all too easy. Here are some pictures of the process and the comparison between the modified and stock zcp. If you live in California and want to go with the 2nd cat delete, try this method and you shouldn't have to worry about the visual inspection. The sound now is noticeably louder with the valves open when listening outside the car. BMW did too good of a job keeping the noise shielded when inside the car so the sound while driving is only a tad louder. 1st picture shows the cut revealing the ceramic core and insulation 2nd picture is the completed cuts 3rd the cats completely welded back. 4th close up of the original cat. 5th sizd by side zcp stock vs zcp catless core 6th car on lift
2019 M4 Conv. zcp 6M, 2020 X3 M40i, 2021 Jeep Rubicon
01-11-2019, 01:54 AM | #3 |
1973
Rep 2,711
Great idea and excellent project! The ceramic honeycomb filter looks restrictive AF! I feel for those who insist on pushing a lot of boost with the factory midpipes in place. It kind of reminds me of what happened to this member: https://f80.bimmerpost.com/forums/sh...6&postcount=92
r0wr589.00 SanchoDivine553.50 |
01-11-2019, 02:45 AM | #4 |
758
Rep 1,336
So in Cali they don't use a heat prob to check if u have a functioning cat? Locally here they have a prob that they wave under the car and should go cold hot cold etc
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
01-11-2019, 08:48 AM | #5 |
131
Rep 91
Great idea and execution 👍. I'll be moving to CA this year and really apprehensive of all the regulations. I was hoping to gut the stock primary downpipe cats, v-band a resonator to the stock muffler and have the stock secondary or highflow cats as another option. Would they really use a heat probe ?? Thought it was all just a visual inspection
01-11-2019, 11:53 AM | #6 |
855
Rep 1,555
Beautifully done! Kudos to you for doing this! I kept my stock secondaries after I cut them out and planned to cut them open. Now I don't have to!
RTCalifornia41.50 |
01-11-2019, 11:59 AM | #7 |
554
Rep 908
That's some surgical level skill with the torch and welding!
RTCalifornia41.50 |
01-11-2019, 12:15 PM | #8 |
1002
Rep 569
Awesome work man.
Can you comment on the effect this has had on the burbles in sport +? Also curious if this has had any impact on drone. |
RTCalifornia41.50 |
01-11-2019, 12:50 PM | #9 |
267
Rep 885
that new CA law will sent him to a referee station. if he was to get cited.
they will measure the exhaust content. I think they will see it's not to spec. always keep the OEM parts on hand in CA. I wonder if the ref station can figure out if loaded with BM3 map. you can always run E85 and have a 'cleaner' exhaust. maybe they won't even care since it's sound related.
SAFE-GUARD tire/wheel/windshield/paint protection is a FRAUD! do not waste your money!
01-11-2019, 07:50 PM | #10 |
#LSBM3
1420
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Clean work! Thanks for sharing!
/// M3 |
01-12-2019, 12:12 AM | #11 |
Love2speed
42
Rep 55
thank you.
Thanks for all comments.
Just a quick sound/video after 2nd cat core delete. After listening to the live exhaust sound and hearing it again on video, I can definitely say the sound clip is missing the true bass rumble and feel. Standing behind the car at cold start with valves open, I could really "feel" the sound. Towards the end of the clip, notice how far the car has driven away from the camera and the distinct exhaust sound is still heard. A special note on the smell: Absolutely no difference compared to stock. i was expecting to smell some un-burn gas or some rich burn but nothing. Here is the revised video.
01-12-2019, 04:03 AM | #12 | |
Love2speed
42
Rep 55
With the valves on auto or activated, no drone in the cablin. Basically its teh same as prior to removal. RT
Tall Tom Cruise1001.50 |
01-17-2019, 05:53 PM | #15 |
3279
Rep 3,256
Looks good! Worth noting though that while this will pass visual inspection, it might not actually pass the smog test. I'm not sure how much "work" the secondary cats are doing but it is possible you might be over the limit. Won't need to worry about that until you need a smog test though.
01-17-2019, 07:14 PM | #16 | |
1973
Rep 2,711
California updated its SMOG policy back in 2011 where vehicles year 2000 and newer are bound to OBD check only with no sniffer test -- https://bar.ca.gov/Consumer/New_Smog_Check_Test.html |
csboi379.50 |
01-18-2019, 12:01 PM | #17 | |
3279
Rep 3,256
One caveat though. I did have to go to a state referee with my 2015 M235i. They did a smog test and actually measured particulates. Avoid the referee though, and you should be fine. |
01-20-2019, 09:24 PM | #20 | |
Love2speed
42
Rep 55
Cell count
1st Picture is front/back 2nd Picture is side RT
02-02-2019, 11:21 PM | #22 | |
Rep 30
