European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      01-07-2019, 12:15 AM   #1
MisterF80M3
MisterF80M3's Avatar
1047
Drives: 2018 M3
Rattle after Active Autowerke Midpipe Installed?
After I installed my AA midpipe, there is a rattle at about low RPM and during startup.
Anyone know if this is normal? It is super annoying.
2018 BMW F80 ///M3
570WHP/578TQ
      01-07-2019, 12:18 AM   #2
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
From other posts, you’ll need to possibly add washers under the support brace to give additional clearance
      01-07-2019, 12:19 AM   #3
FriedPiston
Drives: Scraper
Did you install washers on the middle exhaust brace bolts? If not, the midpipe is likely rubbing against the brace.
      01-07-2019, 12:21 AM   #4
MisterF80M3
1047
Drives: 2018 M3
Hmm.. I'm not sure actually. I will have to ask the shop that installed it.
Where can I buy the washer if it is missing?
2018 BMW F80 ///M3
570WHP/578TQ
      01-07-2019, 12:33 AM   #5
FriedPiston
Drives: Scraper
They don't come with the AA midpipe, or any aftermarket exhaust option.
Ace, Home Depot, Lowes, or any local hardware shop will have them. Just good old flat washers will do; 2-3 washers per bolt, so roughly 12 total.
      01-07-2019, 12:34 AM   #6
MisterF80M3
1047
Drives: 2018 M3
This?
2018 BMW F80 ///M3
570WHP/578TQ
      01-07-2019, 12:35 AM   #7
FriedPiston
Drives: Scraper
This?
That's the one!
      01-07-2019, 01:24 AM   #8
BzsBimmer
BzsBimmer's Avatar
3274
Spacers go on chassis side to give more clearance for the brace. NOT under the bolt head (just in case you weren’t aware)
      01-07-2019, 09:12 AM   #9
Djdnav
227
Drives: F80 M3
If you don’t know where to buy washers, you might want to reconsider modifying your car.
///M3
      01-07-2019, 09:20 AM   #10
MisterF80M3
1047
Drives: 2018 M3
Wtf is your problem?
I thought it was specific washers that AA included with the midpipe.
2018 BMW F80 ///M3
570WHP/578TQ
minn1914037.50
      01-07-2019, 01:24 PM   #11
David@ActiveAutowerke
BimmerPost Supporting Vendor
Drives: M2
The mid pipe can be installed without having to space the brace (although that is a common solution as well). During install, before tightening the ball clamps, we recommend using a small piece of wood or cardboard to space the midpipe between the brace. You can then tighten the ball clamps and remove the spacer. This will allow adequate space between the mid pipe and the brace when everything has been tightened down.
      01-07-2019, 02:01 PM   #12
cwazy1
46
Drives: MG F80 ZCP
They're not specific to the AA midpipe. They are just normal Stainless steel washers that you can get at a hardware store. IIRC, I used 3, 5/8" washers per bolt.
      01-07-2019, 05:43 PM   #13
six-n-twins53
Amateur Tattoo Artist
809
Drives: 2018 M3 zcp
Hahaha
      01-08-2019, 07:46 PM   #14
BayAreaF80
66
Drives: 2016 Individual Fire Orange M3
I had this same issue. Add some washers to add clearance to the cross section. Fixed the issue.
Individual Fire Orange, KW Clubsport 3-way, BMS intake, VRSF chargepipes, Zima V2 DPs, AA midpipe, Hex stage 2, SOLD
Alpine White M4- DD
f80post
