01-05-2019, 10:29 PM | #1 |
865
Rep 765
Cracks in street pads
Hello everyone,
I'm finally getting around to doing all the brake related work on my winter list, which includes swapping back to my street pads. (I experimented last season with a "streetable" track pad that worked okay, but ultimately was very noisy). Anyways, the ones I removed last year have small cracks going down the center, only on the fronts (see pics below). The cracks are only on the very top of the surface, they do not go all the way through the pad. These are the basic PFC carbon metallic street pads. Are they okay to put back on or should I just get new ones? I only ask because they have easily 80% thickness remaining. If I do need to get new street pads - any recommendations besides OEM? I have about a week before I do the work so there is time to order anything I want, and I am interested to see if there are any options that people like. Thank you. |
01-06-2019, 12:55 AM | #2 |
1919
Rep 1,888
Drives: E92 M3
Cracking down the middle is normal, up to a point. There can be moisture retained inside the pad material and bedding in/burnishing brake pads can help get rid of it. Once you see a gap in the crack as thick as a sheet of paper, or it's all the way through, or if there is separation/chunking, that's the time to replace pads.
I keep my track pads and my street pads separate to extend the life of the pads and the rotors. Track pads are too abrasive on rotors when cold and street pads leave deposits on rotors when they're too hot. |
DreamTime864.50 |
01-06-2019, 02:07 PM | #4 | |
865
Rep 765
I totally understand the benefits of separate track/street pads and if I was going to track my car again this year I was gonna just bite the bullet and add pad swaps to my track routine. I am just a very busy person and I thought I would experiment a bit with a "dual-ish" purpose pad and I was pleased enough with the results. If my car ends up doing double duty again believe me I'll do it the right way
Mine: 2008 E90 M3 6MT Hubby: 2019 F87 M2C 6MT Shared: Spec E46 (race car) 2002 E46 330i (daily beater) 1987 E28 535is (garage queen) |
01-06-2019, 02:10 PM | #5 |
865
Rep 765
01-06-2019, 02:15 PM | #7 |
865
Rep 765
Awesome, that's the plan. These pads will see no track time. Thanks for the feedback!
