01-05-2019, 05:53 PM | #1 |
1090
Rep 2,799
Engine break in
What mileage does engine completely break in .... after hitting 5K miles and an oil change i feel the engine has freed up a bit , does it break free completely at 10K?
2021 M2C HS/6MT/Exec/Moonroof
01-05-2019, 05:57 PM | #2 |
4602
Rep 4,265
01-05-2019, 08:28 PM | #3 |
1090
Rep 2,799
So you are saying the miles you take delivery of the car say 5 or 10 miles is not actually that miles if its broken at factory before delivery because there is some engine break in that happens with miles driven on a brand new engine
01-05-2019, 09:05 PM | #4 | |
4602
Rep 4,265
This is why I think break in restrictions are COMPLETE bullshit |
schnell325889.50 |
01-05-2019, 10:01 PM | #5 |
96
Rep 120
Poiseuille5392.50 |
01-05-2019, 10:08 PM | #6 | |
4602
Rep 4,265
Here is a post from another poster that I saved for just these sort of circumstances Car break in QUOTE I am an engineer with one of largest manufacturers of engines in the world, a company that sells billions of dollars of them every year. Items #1 and #2 are terribly incorrect. EVERY engine that we manufacture goes from assembly into a test cell where it is started, warmed up, and sent immediately to 100% full load. Yes, it is "floored." When we do engine testing, even prototype engines are assembled (mostly with Lubriplate 105), warmed up with standard petroleum oil, and immediately go to full rated horsepower while the dyno pulls them down from rated HP to the lowest RPM of torque peak. Almost every automotive manufacturer follows this practice as well. So do motorcycle manufacturers. I personally saw new Ducatis going off the line in Bologna into a chassis dyno where they were started, briefly warmed, and then immediate run up AT FULL LOAD all the way to redline. Why do they do this? 1) The freshly honed/machined surfaces can only do an ideal break-in when they are, in fact, fresh. Once the asperities and surfaces begin to smooth, they lose the ability to mate to each other properly. 2) It prevents customer complaints of high oil consumption and poor MPG because customers tend to follow outdated, bad advice like babying a new engine. Back when machining and honing technology was far less advanced, and tolerances could not be held as well, there was perhaps some validity to babying a new engine. But this advice is woefully out of date. Instead, the best thing you can for a new engine is: 1) Warm it up to full operating temperature 2) Do several full throttle runs that stop well short of redline 3) Idle the engine to let it cool a bit 4) Repeat steps 2&3 several times 5) Change the oil and filter. Done. By and large, new engines require almost no break in at all because of the "abuse" they suffer at the factory. That's why they can ship new cars like Corvettes with Mobil 1 from the factory. No need to worry about the syntehtic preventing break-in when the engine is already broken in before installed in the car. |
01-05-2019, 10:18 PM | #7 |
96
Rep 120
@///M4ster Yoda thanks for the info!
///M4ster Yoda4602.00 |
01-06-2019, 06:53 PM | #8 |
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
01-06-2019, 07:49 PM | #9 | |
1090
Rep 2,799
01-06-2019, 08:02 PM | #10 | |||
1973
Rep 2,711
Link to original post: https://f87.bimmerpost.com/forums/sh...3#post22139303 Quote:
01-06-2019, 08:16 PM | #11 | ||
4602
Rep 4,265
FSociety3812.50 |
01-06-2019, 08:18 PM | #12 | ||||
4602
Rep 4,265
01-06-2019, 09:13 PM | #13 | |||
4998
Rep 6,863
On another note, I find it hard to believe that BMW (and countless other manufacturers of performance vehicles) would go out of its way to specify a break in protocol if there was absolutely no merit to it and in fact the complete opposite was true. |
overlook637244.50 Poiseuille5392.50 |
01-07-2019, 08:30 AM | #14 | ||||
4602
Rep 4,265
I can see the validity in getting used to brake feel and the handling of a new car. What I don't understand is BS breakin protocol for an engine that is already broken in before it even enters the vehicle. Do you believe everything your told/read? I sure don't. Plenty of ulterior motives out there. I'm gonna continue to disregard this BS. We are doing ED again this spring on another ///M4 and will blast out of the Welt onto the Autobahn immediately. You only live once |
01-07-2019, 09:33 AM | #15 | |
4998
Rep 6,863
As for "believing everything I am told/read" , of course not but I dont think this is an instance of subjective opinion left open for interpretation. If following the break in procedure is absolutely BS as you believe it is, why would BMW go out of its way to detail out certain protocol to be followed? And why would so many other manufacturers? Do you really think they are putting this information in the manual just to mess with us consumers or that perhaps they truly believe this is the best way to ensure the engine performs up to its intended standards? I am mainly playing devils advocate here and I am not suggesting that deviating from BMWs prescribed procedures will somehow make the car run like junk. But I believe they put those instructions in there for a reason (and because of some fictitious legal liability). |
01-07-2019, 01:32 PM | #16 | |
141
Rep 258
BMW: Did you follow the break-in procedure from the manual? Customer: No... If it does anything or not, it's an out for BMW. Enough that they log the data for the first 2000km, see you exceeded 5500rpm, see you exceeded 170kph etc. That being said - other parts need breaking in. The tires, the brakes, the diff, even the speakers.
2019 M4 ZCP / Yas Marina Blue
M-Performance Front Splitters / M-Performance Rear Spoiler / Rieger Tuning Side-skirt Extensions / Carbonwurks Rear Diffuser / Alcantara M-Performance Interior Accessories |
01-07-2019, 03:06 PM | #17 | |
4998
Rep 6,863
01-07-2019, 03:29 PM | #18 |
935
Rep 1,930
I drive all my new cars like I stole it from day 1. For some reason my oil consumption is much less compared to some of my buddies who did the "soft break-in".
schnell325889.50 FSociety3812.50 |
01-07-2019, 03:37 PM | #19 |
Bored at work....
890
Rep 5,391
Flat out from the first day, as any European Delivery customer does
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
01-07-2019, 03:50 PM | #20 |
1090
Rep 2,799
Folks
To keep this thread as per original subject i am trying to find out whether engine breaks in at periodic intervals (miles) or already broken to its max from day1, this is not a thread where we will discuss whether one has followed the BMW Recommended break in procedure.
Poiseuille5392.50 |
01-07-2019, 04:42 PM | #21 | |
4602
Rep 4,265
/thread |
Tall Tom Cruise1001.50 |
01-07-2019, 06:22 PM | #22 | |
1183
Rep 1,220
