proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      01-04-2019, 11:52 PM   #1
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
F8X S55 owners BEWARE!! Charge cooler failure
Hello everyone,
I'm not around on this Section of the forum but have and still am gaining more knowledge of the S55, but am knowledgeable to the N54/N55 platform and linger on e90post/1addicts. Recently a buddy of mine with a F80 M3 has been receiving drivetrain malfunctions, down on power, and extremely hot air intake air temps, the charge air cooler as you guys know should be cool to the touch.
Car goes into diagnostic at a local performance shop and find this: (see images below). After pulling the intake manifold off the car.
Yes that's right, seems like the factory charge air cooler has leaked the cooling fluid through the core and gone directly into the intake manifold, and through the intake valves directly into the engine. From what I've seen this is the first that has happened on this platform. The car will be repaired and back running in a few days. But as a PSA seems like upgrading the stock heat exchanger to prevent a 2k+ failure/repair like this is the way to go.
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
Appreciate 17
      01-05-2019, 12:25 AM   #2
guess2098
Drives: 2022 Taycan GTS, 2018 M4, 2016
Good info, thank you
      01-05-2019, 12:31 AM   #3
NickyC
NickyC's Avatar
17485
Drives: M4 CS. Former G82, x2 F82, F80
Good grief, isn't there a danger of hydrolock there?
Thanks for the info.
bmwbrad22249.00
      01-05-2019, 12:36 AM   #4
WeekendWarriorz
670
Drives: 2006 Z4M
Absolutely, I'm surprised it didn't hydrolock... but after the fluid drained into the engine it either went into the oil and can cause excessive wear on rotating parts (rod bearings for example) or evaporated with the heat generated from combustion. Whichever happened though it isn't good!
Appreciate 5
NickyC17484.50
knepsterd376.50
EBII33533.50
      01-05-2019, 12:51 AM   #5
FriedPiston
Drives: Scraper
Mind sharing what kind of DTCs your friend was seeing?
      01-05-2019, 01:07 AM   #6
WeekendWarriorz
670
Drives: 2006 Z4M
This was it if I recall correctly
      01-05-2019, 01:34 AM   #7
Justin.AutoTalent
3138
Drives: F80 M3
Was the car worked on before and what modifications does it have?
      01-05-2019, 01:45 AM   #8
WeekendWarriorz
670
Drives: 2006 Z4M
The car has only seen Newport Beach BMW and Mckenna BMW for routine service since new, both reputable dealerships in SoCal. Previously had a JB4 (junk box 4) on it over a year ago with a few hundred miles before being taken off is what I'm told. Nothing that could have been correlated to the failure In my opinion.
      01-05-2019, 11:09 AM   #9
maximumpsi
Drives: 16 M3, 02 M3
2016 BMW M3  [0.00]
We have replaced two so far. Not caused by any mods. Both were internal core leaks.
Appreciate 8
qmp123.50
hellokitty2895.50
Relak247.00
kern4174449.50
JTO245276.00
      01-05-2019, 11:25 AM   #10
Groganrocket
380
Drives: 2010 e90 335i and 2015m4
What year and mileage.
      01-05-2019, 11:30 AM   #11
maximumpsi
2016 BMW M3  [0.00]
one 15, one 16.
50k+ on first one, correct fluids and maintenance. Other was lower mileage. If you are losing fluid from the HX reservoir you know where its going if it isn't on the ground.
Appreciate 3
      01-05-2019, 12:11 PM   #12
WeekendWarriorz
670
Drives: 2006 Z4M
This is a 2018, I believe around 15k miles.
      01-05-2019, 12:23 PM   #13
///F80M3
///F80M3's Avatar
Drives: 16 AW M3
Mine was leaking too and I had no codes. It's best to check the IC reservoir to if its leaking or not.
2016 M3
Alpine White / Sakhir Orange
BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount)
Appreciate 3
      01-05-2019, 03:30 PM   #14
MDM
MDM's Avatar
254
Drives: /// 2022 M8C
This doesn’t surprise me at all… However that is not the only place it can leak from as I found out about four months ago my charge coolant expansion tank had to be replaced because I had a slow leak although I saw no evidence or could smell anything either which was extremely odd. I just knew it was leaking internally. All is good now :-) sidenote, both my charge cooling expansion tank and engine block coolant expansion tank have been replaced one each. 2016 M4
      01-05-2019, 04:19 PM   #15
hellokitty
hellokitty's Avatar
Drives: '17 M3 ZCP DCT
This doesn't surprise me at all… However that is not the only place it can leak from as I found out about four months ago my charge coolant expansion tank had to be replaced because I had a slow leak although I saw no evidence or could smell anything either which was extremely odd. I just knew it was leaking internally. All is good now :-) sidenote, both my charge cooling expansion tank and engine block coolant expansion tank have been replaced one each. 2016 M4
How did you find out there was a leak? I'd like to check my car. Haven't had to add a whole lot of coolant but maybe half a cup every few thousand miles.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      01-05-2019, 08:08 PM   #16
M3anPower
176
Drives: F80 M3
So I should call CSF ASAP now.
Thank you for taking your time and sharing the information.
      01-05-2019, 09:01 PM   #17
WeekendWarriorz
670
Drives: 2006 Z4M
Better to be safe than sorry. Seems like there's been a few of these and no one has documented this failure. A used S55 + labor for a swap doesn't sound cheap as opposed to a CSF cooler in my opinion!
      01-05-2019, 09:16 PM   #18
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Water injection
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
Appreciate 5
      01-05-2019, 11:52 PM   #19
MPOOR
MPOOR's Avatar
Drives: F80 M3 / WHITE
One of my buddies brand new M3 comp pack had same issue ~ 9941miles on a 2017 model. He's getting is replaced under warranty
What shall i buy for my next track toy
      01-06-2019, 08:48 AM   #20
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
For us laymen, is this something we could check and if so how?
      01-06-2019, 08:52 AM   #21
Harpinc
94
Drives: Audi RS3
This is common on boosted cars. You realistically should have NO fluid consumption in the intercooler.
      01-06-2019, 12:34 PM   #22
WeekendWarriorz
670
Drives: 2006 Z4M
Open up the reservoir for the charge air cooler, I would just monitor it every few weeks. If you notice fluid dropping then there would be a concern. For example: you could use a straw and then the first time you measure use a sharpie and mark the height of the fluid.
Appreciate 11
f80post
