12-14-2018, 01:23 AM | #1 |
Rep 45
brake wear sensor
so it had shown that my brakes are bad, i replaced it and noticed that my brake wear sensor was also torn so i replaced that too but the dash still showing up the error and it doesnt show any milage on the brakes. i wonder what causes the problem, now i have to drive with a red brake light on the whole time
12-14-2018, 07:06 AM | #2 |
5234
Rep 10,616
You need to reset the brake warning light. Google that and follow the process. I did it recently. No special tools required.
M3ANMACHINE931.00 |
12-14-2018, 10:46 AM | #3 |
Rep 45
12-30-2018, 03:57 PM | #4 |
Lord Scrip
1815
Rep 3,013
Drives: 2011 M3 Coupe
Two fronts and one back, 3 sensors total. Chances are you replaced 1 sensor but the other has worn as well. I would replace both fronts and reset.
01-02-2019, 04:56 AM | #5 |
Rep 45
yea i had just noticed that there was actually 2 in the front, the bmw place told me it was only 2 on the car which was both on passenger side
01-02-2019, 08:18 PM | #6 | |
Lord Scrip
1815
Rep 3,013
01-02-2019, 11:35 PM | #8 |
Lord Scrip
1815
Rep 3,013
Right on!
06-05-2021, 12:20 AM | #9 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
Will the OEM brake pads work with Brembo brake kit? TIA
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
06-05-2021, 12:25 AM | #11 |
1131
Rep 5,557
I contacted my local shop and they confirmed the regular pads would work but not the track version.
06-05-2021, 12:56 AM | #12 | |
3900
Rep 4,165
Top pic is Brembo front pad shape. Bottom pic is stock front pads. |
06-05-2021, 01:06 AM | #13 |
1131
Rep 5,557
Redd,
Thanks for the info all pads do have a cut out on the pads area is that where the sensor is located?
06-05-2021, 01:14 AM | #14 |
3900
Rep 4,165
Edited - Oh you're asking about the wear sensors. Yes some aftermarket pads allow you to re-use the wear sensors. But most people do not bother.
06-14-2021, 05:31 PM | #15 |
57
Rep 412
Ran into this ... If i recall i posted on another thread ... You need plug and unplug a few times. If i recall
