12-06-2018, 06:36 PM | #1 |
903
Rep 1,003
Drives: 2008 BMW 135i (E88 N54 6AT)
I've run a number of crappy-brand 255/35R18 tires on the back of my E88 without issue; but (thankfully) upgraded to MPS4's recently.
Unfortunately, they seem wider than usual, and are rubbing on the outside whenever I go over a bump. As a result, the outside shoulders of the tire are being torn to shreds by the body of the car. I'm interested to know others' experiences; and especially what your recommendations are for a fix. Should I get the guards rolled (and if I do - should I do the fronts at the same time and does it open up the possibility of even wider tires) - or should I keep a close eye on it and go 245's next time? Last edited by xQx; 02-13-2023 at 09:15 PM.. |
12-06-2018, 06:49 PM | #2 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
That's pretty bad. I'd take it to an alignment shop to have them increase your rear camber.
Rolling and pulling will help somewhat. But I bet you are mainly rubbing where the rear bumper connects to the fender and it's hard to do much with that area. Michelin's don't so much run big as many cheap tires run small. Many of us have been through this but mainly because we have aftermarket wheels.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
xQx902.50 |
12-06-2018, 08:12 PM | #3 |
19
Rep 179
Are you on stock suspension?
I used to have Hankook S1 Evo2 in 255 for the rear. Couple months back I went for the new Conti Extreme ContactSport also in 255. The Contis were definately wider than the Hankooks but I have yet to experience any rubbing whatsoever. |
12-16-2018, 03:38 AM | #5 |
43769
Rep 7,224
You're speaking about the Michelin Pilot Sport 4, and not the Michelin Pilot Sport 4S, is that correct? I ask because I have just purchased Michelin Pilot Sport 4S 225/255 for my car (not installed yet), but I have the the Michelin PSSs in 225/255 that fit with no issues at all and I assume the MPS4Ss will fit the same as the MPSSs.
12-16-2018, 08:27 AM | #6 | |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
12-16-2018, 08:57 AM | #7 |
4338
Rep 6,196
Looks like you just need an alignment and increase rear camber to -2.2 or so.
Was having the same problem with my 265's on one side. Thought I had -2.0 on both sides. Turns out our alignment rack was off, and actually had -1.4 on one side and -2.6 on the other when I redid it on our new alignment rack. |
12-16-2018, 07:29 PM | #8 | |
903
Rep 1,003
I've never had MPSS or MPS4S's on the car, so I can't compare. Essentially the only other 255's I've had on were some cheap shitty asian brand tires. I'm in a convertible with M-Sport suspension, so I might be lower than the average 1er. It's less of a problem with -2.0 camber; but still not completely cured. |
Esteban43769.00 |
01-24-2019, 01:45 PM | #9 |
Rep 14
Drives: 2013 BMW 135i Convertible
Why not just buy the right size tire for your car? I don’t get why people always buy oversized tires and wheels that don’t fit.
01-24-2019, 02:02 PM | #10 |
496
Rep 476
01-24-2019, 03:59 PM | #11 | |
903
Rep 1,003
So, why do people bother running bigger tires than stock; well, for starters, BMW gave us shitty runflats, so you can't exactly say they chose the best possible tires for performance out of the factory. Now, simple physics tells us that running wider tires does nothing to increase the overall size of the contact patch between the wheel and the road; it just changes it from a long skinny contact patch to a wide and short contact patch - so, the amount of friction between your car and the road doesn't change. BUT, tires rely on adhesion to stick to the road, not just friction; so you're really not going to know if it does anything until someone does some real-world side-by-side testing on a track to see if wider tires mean faster track times or shorter stopping distances. Oh wait, they have. Now, I don't know about you; but in my little car, the biggest impediment to me accelerating faster below 100kph is my rear-wheel traction; and my personal preference is to have a car with the shortest possible stopping distances - so it seemed worthwhile to run better and wider tires than BMW shipped the car with from the factory. |
01-25-2019, 11:57 AM | #12 | |
496
Rep 476
xQx902.50 |
