12-03-2018, 02:07 AM | #1 |
88
Rep 238
Drives: BMW M6 comp
Garage List 2019 Aprilia RSV4 [0.00]
2015 Land Rover Ran ... [0.00] 2014 MV Agust Rival ... [0.00] 2009 KLR650 [0.00] 2016 Kawasaki KX450F [7.50] 2016 BMW S1000RR [8.50] 2014 BMW M6 [8.00] |
weird issue today
Was at the gas station, with 24 miles on estimated range, car all of a sudden coughs, and throws up an error like a transmission fault, car still moves but with a weird noise. I shut it off, fuel up, and restart. Cars fine, has a CEL. Check it out with a reader at home and found a few codes, System too lean in Bank 1/2, Fuel Rail pressure sensor (Pressure high before engine start).
I clear out the CEL via the reader and its all back to normal. Was a SUPEr weird hiccup, I do have a BPM sport tune but its been flawless so far. Coils/plugs are all done as of 5k miles ago. Not sure if weather plays a part, but its probably the coldest i've driven the car in post tune. In touch with BPM and they suggested to wait and see what happens / if it happens again.. Any feedback appreciated if anyone has faced a similar issue.. PS car has bmc race air filters and thats the only mod besides the tune |
12-03-2018, 06:13 AM | #2 |
19
Rep 126
Are you not running the tank a bit low with only an estimated 24 miles left? I was advised not to run it down to the dregs because you're more likely to suck any residual crud that could be in the bottom. That applied to any car...
12-03-2018, 01:59 PM | #3 |
88
Rep 238
Drives: BMW M6 comp
it was a bit low, i'll try to not do that again!! Not sure if that was the culprit, but it makes sense..
12-03-2018, 08:46 PM | #4 |
252
Rep 631
Drives: 2014 M6 Grand Coupe CP
when you get that low, you can loose suction on the fuel pump in a long turn or under braking or acceleration. That theory is supported by the low fuel rail pressure code. It can damage your fuel pump doing that.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
12-04-2018, 12:42 AM | #5 |
88
Rep 238
Drives: BMW M6 comp
Makes sense, I was however, crawling up on the costco gas station, at like 1mph when it happened...
