11-24-2018, 09:00 AM | #1 |
3663
Rep 3,422
Off-season, thinking CS (763M) wheels + slicks, brake replacement
Thinking about a 2nd set of wheels w/ slicks. Drawn to maintaining BMW wheel specification/stagger on the GTS, so the 763M wheels look like a good option.
Lose 0.5" of wheel width out back, but the 285 section Hoosier R7's that I'd want to fit are 0.2" narrower than the 285 section star spec Cup 2's. If BMWPARTSPROS are accurate with their weights, a 763M setup would be notably lighter than the GTS 666M. 3.25# less front per corner 5# less rear per corner 16.5# reduction overall 763M by FormulaMMM, on Flickr Add to the mix rear Hoosier R7, which save another 2# per corner. (Front R7's are equal to the OE Cup 2's.) 20.5# reduction overall Thoughts? Overlooking anything? Seems like a nice middle ground between stock and BBS FI-R… (https://f80.bimmerpost.com/forums/sh....php?t=1155359) Long way off hopefully, but on the subject of carbon ceramic brake replacement, this the best published deal out there? https://www.ecstuning.com/b-genuine-...t/34112358378/ I see from some past threads that BMWPARTSPROS sold the retrofit for 10k. Seems like a "good deal" as compared to front disk replacement alone at almost 8k. https://www.ecstuning.com/b-genuine-...SABEgJZefD_BwE Only catch being that the GTS pads are a different compound than the standard carbon ceramic kit, I think.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
11-24-2018, 09:21 AM | #2 |
21121
Rep 20,741
Drives: 2021 911 turbo
It’s an interesting thought. I do like the 763M wheels a lot. However, if it were me, I’d actually go wider for dedicated track wheels: 10”~10.5” front and 11” rear to be able to fit wider tires. Wider tires will heat less and therefore grip more, be more consistent and wear less.
As for the pads, if I’m not mistaken, only the GTS rear pads are different than the non-GTS CCB.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 11-24-2018 at 11:00 AM.. |
11-24-2018, 10:34 AM | #3 | |
3663
Rep 3,422
Yeah, counter to my natural instincts too. Never stayed OE tire specs or gone with a narrower wheel on a track setup. This is based on 2 track days so far with the GTS. Agree that more tire never hurts, but found rear traction pretty much ideal. It understeered, but that's because about the outer 1/3 of the front tire contact patch was working for me. Camber plates, especially in combination w/ slicks, should resolve. I'm afraid to change the balance of the car, put bulkier wheels + tires on, lose any tactility, etc. Also don't know about clearance and geometry issues. So anyways, I'm not finding much of a performance need to deviate from OE wheel + tire specs, like was an obvious requirement on the E90. Any wider aftermarket wheel + tire setup will come with a weight penalty. This potential setup saves pretty substantial weight and the R7's are right there for the taking in OE sizes. Oh, and vanity. I like the 763M… Thanks for the thoughts.
11-25-2018, 04:13 AM | #4 |
drunk poster
6614
Rep 3,649
Wouldn’t it be better to go to someone like Forgeline and have them make an even lighter wheel to exactly the spec you want? They’re pricier than OEM, though.
11-25-2018, 07:32 AM | #5 | |
3663
Rep 3,422
Here's an unconventional fitment: https://f80.bimmerpost.com/forums/sh...2&postcount=31 Believe that was before Apex made a 19" wheel that was a fit for the rear. New Apex SM-10 is available 19x10 front and 19x11 rear. Great looking specs, seems like a good option to me this a.m. Nothing but positive experiences with Apex wheels. Could probably run R7's in 295 front, 315 rear. Based on projected SM-10 weights, would still end up with a net loss vs 666M. I'm just nuts enough that the narrower 763M rear wheels and corresponding loss in tire section width will probably bother me, so moving away from that idea.
11-25-2018, 08:41 AM | #6 |
30
Rep 375
I am thinking about getting Forgeline GS1 or GA1R 19x9.5 + 29 offset and 19x10.5 + 38 offset with R7s.
____________________________
2016 BMW M4 GTS - Frozen Dark Grey Metallic 2018 Porsche 991.2 S - Fashion Grey 2013 X5 35D - Alpine White 2011 E92 M3 - Monte Carlo Blue - Sold |
11-25-2018, 01:14 PM | #7 |
3663
Rep 3,422
So you'd stick with 265 front 285 rear?
11-25-2018, 08:45 PM | #8 |
30
Rep 375
295 in the back and 265 in front is what I am being told is the option with R7. Should have mentioned earlier.
11-26-2018, 10:19 AM | #9 | |
3663
Rep 3,422
https://www.apexraceparts.com/shop-b...-10-wheel.html https://www.apexraceparts.com/shop-b...-10-wheel.html Tried to get a good glimpse of the inboard clearance yesterday. Jacked up the front end and snapped some pics. This is with 275 Cup 2’s fitted – 11” of section width as compared to 10.7” for the OE 265, tread width of 9.5” vs 9.2” for OE 265. [IMG]IMG_1610 by FormulaMMM, on Flickr[/IMG] [IMG]IMG_1616 by FormulaMMM, on Flickr[/IMG] 295 R7 up front with 11.5” of section width, and 10.5” of tread width seems iffy. Not sure if that GTS above was running spacers, wasn’t lowered, adjusted ride height for optimum clearance, something. 265 R7’s are +0.3” tread width vs OE 265 Cup 2. 295 R7’s are +0.1” tread width vs OE 285 Cup 2. In combination with 10” wheels front, 11” wheels rear, should be a nice expanded footprint front & rear with handling balance kept pretty consistent.
erictrainer277.00 |
11-28-2018, 03:38 PM | #10 | |
30
Rep 375
11-29-2018, 07:33 AM | #11 | |
3663
Rep 3,422
Ran 18x10 ET25 front (w/ 275s) for years on my E90 with KW Clubsports and Eibach springs, so thinking it should be just about perfect.
11-29-2018, 11:28 AM | #12 | |
Bored at work....
891
Rep 5,393
Unfortunately I’ve never snapped any pictures :/
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
11-29-2018, 12:38 PM | #13 |
3663
Rep 3,422
Nice! Thanks. What are rear wheel + tire specs? Do you have the Apex SM-10s?
11-29-2018, 02:12 PM | #14 | |
3663
Rep 3,422
11-29-2018, 07:57 PM | #15 | |
Bored at work....
891
Rep 5,393
I am actually running a square setup, so same specs on the rear. I’m using their PS-7 wheel.
11-29-2018, 07:59 PM | #16 | |
Bored at work....
891
Rep 5,393
11-29-2018, 08:05 PM | #17 |
Bored at work....
891
Rep 5,393
11-29-2018, 09:02 PM | #18 | |
21121
Rep 20,741
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
11-29-2018, 09:19 PM | #19 |
Bored at work....
891
Rep 5,393
Silly me Added one of them on my F80.
12-01-2018, 07:57 AM | #20 | |
3663
Rep 3,422
I can't find any spec Cup 2 in size 285/30-19 other than that run flat linked above. You have a Canada special? Nice plate, by the way.
schnell325891.00 |
12-01-2018, 10:48 AM | #21 | |
Bored at work....
891
Rep 5,393
I get mine from Costco Canada. I’m not sure the production date code, but they’re still listed
12-01-2018, 01:35 PM | #22 | |
3663
Rep 3,422
Like them and the square setup? Did you run the OE star spec Cup 2's and stagger initially, i.e. can you compare the two setups? Thanks
