11-07-2018, 10:25 PM | #1 |
2751
Rep 6,759
Anti-dazzle and VLD in 2018 cars?
Hi,
I just had a reputable board sponsor code my 2018 ZCP for anti dazzle, which apparently includes the variable light output feature. But I cannot tell that either of these are working... Are these features incompatible with 2018 models? if not then how can I tell they are working? Perhaps I’m not looking at it the right way I don’t know... any help is appreciated.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
11-08-2018, 12:44 PM | #2 |
24
Rep 38
Hi adc --
I would read the thread linked below, from around page 64 to the end. It appears to me at least that whether or not these items work properly is highly dependent on when your car was manufactured -- for example, mine was made in the middle of July 2017 and anti-dazzle doesn't work correctly (I get headlight motion that looks generally correct but a lot of light leakage onto cars in front of me), but people with 2018-model cars manufactured earlier in 2017 seem to be able to enable the features without a problem. Apparently there was a headlight hardware switch at some point. In any event, good luck! https://f80.bimmerpost.com/forums/sh...086530&page=64 |
11-08-2018, 09:35 PM | #3 | |
2374
Rep 8,364
LCI (2018 with FLE): hardware not capable of NGHB. |
Drei300014.50 |
11-16-2018, 08:57 AM | #5 | |
158
Rep 139
I never drive on dark straight roads, so I'm not able to fully test it to determine if I have the "light leakage" issue, but with what I was able to see NGHB was definitely working to some extent (or at least trying to work -- I could see the beams moving around/turning off on oncoming cars).
2018 F80 M3 • Silverstone/Silverstone • DCT/ZCP/Exec/Assist/Blind Spot
2016 B8 S5 |
11-16-2018, 05:06 PM | #6 | |
2374
Rep 8,364
11-16-2018, 05:44 PM | #7 |
21117
Rep 20,741
Drives: 2021 911 turbo
It seems to work decently well on my 2019 M4cs.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
11-16-2018, 06:13 PM | #8 |
158
Rep 139
That's what I'm trying to say as well. Seems to be working on my '18. If it works as well as it did with the old lights is a different story. But to say flat out that the hardware is not compatible seems like a misstatement.
2016 B8 S5 |
11-16-2018, 06:46 PM | #10 | |
2374
Rep 8,364
EDIT: Here is list of capable cars. Last edited by Almaretto; 11-16-2018 at 09:54 PM.. |
11-18-2018, 07:30 AM | #11 | |
21117
Rep 20,741
cotmfk2050.50 |
11-18-2018, 04:18 PM | #12 | |
2374
Rep 8,364
11-18-2018, 04:43 PM | #13 |
21117
Rep 20,741
Well if my lights do not glare anyone, isn't that anti-glare high beams ?
11-18-2018, 09:19 PM | #14 | |
2374
Rep 8,364
https://www.2addicts.com/forums/show...postcount=1852 |
CanAutM321116.50 |
11-19-2018, 09:45 PM | #15 | |
21117
Rep 20,741
Almaretto2374.00 peteyfresh129.50 |
11-23-2018, 01:49 AM | #16 | |
The G8X is a disaster. 🤮
931
Rep 988
It’s not enough to just see it from your perspective when trying to verify it works. Try to film it with a second car. |
11-23-2018, 04:49 AM | #18 | |
21117
Rep 20,741
It really makes you wonder why BMW went through the trouble of changing the headlight hardware on North American cars so NGHB does not work properly. It does not make sense to me why they would do that.
11-23-2018, 10:33 AM | #19 | |
136
Rep 453
11-23-2018, 04:13 PM | #20 | |
2751
Rep 6,759
I suspect the headlight changes have to do with US DOT compliance.
11-24-2018, 07:17 AM | #21 |
29
Rep 119
So I also have a 2018 F80. I did the coding and in Germany i get flashed every once in a while so i stopped using this. What hardware is incompatible? Can i swap out headlights or modules to be able to correctly use this? Any help is appreciated thanks in advance
11-24-2018, 09:29 AM | #22 |
21117
Rep 20,741
My thought also.
Frustrating these archaic regulators that limit us having access to breakthrough technologies. Transport Canada is no better, they just follow whatever the DOT does. I have a feeling that there is a lot of politics and economics at play here from the regulators. Since American manufacturers do not yet offer that technology, I am guessing the regulators are banning the technology to avoid giving a competitive edge to the European and Japanese manufacturers.
