11-07-2018, 11:07 AM | #1 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
467M wheels and MPBK
Should 467M wheels work with MPBK?
Because mine obviously do not.
Freude am Fahren.
11-07-2018, 11:33 AM | #2 |
Freude am Fahren.
835
Rep 1,287
What color are MBPK? Looks like I will need some paint job...
Freude am Fahren.
11-07-2018, 12:07 PM | #3 |
7435
Rep 11,846
Drives: MY24 G01 AW Msport
how did you notice that? |
11-07-2018, 12:16 PM | #4 |
Freude am Fahren.
835
Rep 1,287
Well, it was hard not to notice. I put my winters on on one side and decided to move my car to work on the other side when I heard a really bad noise and car was not rolling... So I went out and saw this.
Was so sure that OEM 19’’ should fit and they actually almost did, so I haven’t checked if rims were touching anything...
Freude am Fahren.
nyalpine907434.50 |
11-07-2018, 12:39 PM | #6 |
Freude am Fahren.
835
Rep 1,287
I think I’ll try spacers first.
Just wonder - no one with 467 and MBPK here?
Freude am Fahren.
11-07-2018, 01:40 PM | #7 | |
200
Rep 178
First Pic is with the spacer. Second Pic is without the spacer. |
11-07-2018, 01:42 PM | #8 | |
Freude am Fahren.
835
Rep 1,287
Freude am Fahren.
11-07-2018, 06:28 PM | #10 |
2114
Rep 2,388
Damn...
Here's some pics of 19'' rims that clear MPBK without issues and no spacers - the only difference I see is that they have ///M badge on the rim - maybe that means they are designed to clear MPBK? But then again 19'' M wheels are laughable. Why would BMW even make 19'' M wheels? I'm not really sure what's going on here. |
1230vani657.00 |
11-07-2018, 07:29 PM | #12 |
2114
Rep 2,388
Well I guess it's just one of those unsolved mysteries of x5 f15 that we will never find an answer. Just put spacers then and be done. It will look even better.
Update: I think I might know the answer, but i could be wrong too. All that 19'' rims are initially not made for x5 aren't they? I mean BMW will never make a tiny 19'' M wheel for x5. No way. 467M and some other rims on my pics above (don't know their style number) - are probably from some 3 series. So in that case - it makes sense, as MPBK are huge and rims have to be for x5 in order to clear them. IMHO real M rims for x5 start from 21'' |
11-07-2018, 09:13 PM | #14 | |
2114
Rep 2,388
OP is the other caliper on other side ok? I mean it's either both calipers would not clear or both would touch rim and get stuck - right? It can't be that just one decided to be a bad boy? Doesn't make sense. More likely that side caliper was not installed properly? I'm not sure. Can you post more photos so we can see whole rotor with caliper? Last edited by DuSh; 11-07-2018 at 09:18 PM.. |
11-07-2018, 09:18 PM | #15 | |
1142
Rep 714
Drives: BMW X5 M Sport - G05
DuSh2113.50 |
11-07-2018, 09:20 PM | #16 |
2114
Rep 2,388
Ah I see. Ok then. I never thought BMW would make an ///M wheel in such a small diameter. Yes, I know about 18'' rims, I was just surprised why in the earth BMW would put an M badge on such small rims. That's even worse imho than putting an M badge on rear lid lol.
11-07-2018, 09:57 PM | #17 |
197
Rep 535
Only 19 inch wheels that came with the m sport models will clear mpbk was what I was told. Otherwise you need 20 or more. I learnt the hard way too luckily I had taped the caliper before I put the wheels on and saw the front rub. Used spacers.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
11-07-2018, 10:51 PM | #18 | |
Freude am Fahren.
835
Rep 1,287
Not sure what's your problem with 19'' - they look ugly, but they work the best for winter.
Freude am Fahren.
11-07-2018, 10:53 PM | #19 |
Freude am Fahren.
835
Rep 1,287
Thank you! I would assume that mine were not installed correctly.
Freude am Fahren.
11-08-2018, 04:06 AM | #21 |
68
Rep 124
If I recall the spec sheet for MPBK said you must have minimum 19" wheels or they won't fit. Sounds like the install was not done correctly, like you said.
11-08-2018, 04:31 AM | #22 |
48
Rep 103
I believe this might the problem.
These are the specs i found for these wheels: https://www.carsaddiction.com/en/wheels/BMW/Style-467 They were probably mounted incorrectly (front on back). |
CatalinP589.50 |
