11-04-2018, 05:16 PM | #1 |
Rep 25
E92 M3 Front Control Arm Monoball Bushings
Hello everyone,
I am currently refreshing my suspension arms as my car now as 80,000 miles on and under my ownership will see regular track use. One area I am keen to improve is the huge movement under braking and to that end, wish to upgrade to front control arm monoball bushings. I see there are many options - Millway, Bimmerworld, FallLine, SPL Components etc Is there a consensus as to which is the "best" - or is it a case that they're all pretty much as good as each other? If it makes a difference, my car isn't used through winter. Many thanks |
11-04-2018, 08:43 PM | #2 |
3549
Rep 2,824
Dinan is fantastic, but not the cheapest. Bimmerword is also very popular and a little cheaper. Many reports of noises with the Turner units.
Fall Line is good but unsealed, whether or not that matters depends on the conditions you’ll drive in. |
11-04-2018, 09:18 PM | #3 |
Latif
265
Rep 378
I agree.
Instagram: latif_eshaq
11-05-2018, 10:56 AM | #5 |
3549
Rep 2,824
I’ve read mixed things about how durable the stock bushings are, some say they wear out like E46 RTABs, others say they last a long time.
I’m at 50K now and I can feel the play/movement but my bushings don’t look that bad or worn to the eye. At $20/ea, I have some new OE Lemforder units ready to go in. I want to see how fresh stock feels before going monoball. If no different then I may look at monoballs too. |
11-05-2018, 04:03 PM | #6 |
94
Rep 114
German Auto Solutions. They are nearly identical to Dinan and cheaper. The quality is amazing.
ARC-8 Wheels - Stoptech Trophy BBK - Solid Subframe Bushings - Purple Diff Bushings - Topspeed X-pipe - Megan Catback - AFE Carbon Intake - RE Pullies - BPM Tune - GAS Monoballs - ECS Front Sway - GTS Wing - Autosolutions SSK - Vibratechnics Motor Mounts - Revshift Tranny Mounts - VAC Bearings - Bilstein PSS10 Coilovers - Dinan Camber Plates - Ultra Front Strut Bar - BSW Ghost Subs - Matek Diffuser
11-11-2018, 06:39 AM | #9 |
119
Rep 423
Aren't poly bushes a middle ground between stock and monoball?
11-11-2018, 12:43 PM | #10 |
4100
Rep 1,612
strokemycocktus119.00 |
11-11-2018, 12:45 PM | #11 | |
119
Rep 423
I take it that there was a noticable improvement in steering responsiveness?
StripclubDJ4100.00 |
11-11-2018, 12:50 PM | #12 | ||
4100
Rep 1,612
They help with braking response aswell |
11-11-2018, 12:53 PM | #13 | |||
119
Rep 423
11-11-2018, 12:54 PM | #14 | ||||
4100
Rep 1,612
07-24-2019, 10:19 AM | #15 |
910
Rep 2,091
Sorry to bring up an old thread but are you running these?
PFF5-401B https://www.bimmerworld.com/Suspensi...-PFF5-401.html
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
07-26-2019, 01:30 PM | #16 |
3549
Rep 2,824
Went to a shop to have the OEM FCABs pressed in (not a DIY unless you get new arms with FCABs already in) and they said I'd be silly to pay them for the work since mine looked just fine. So, I returned the Lemforders, but I am still not happy with the shimmy under braking. So I'm back to thinking about these as well.
I am not sure if this bushing rotates like the E46 RTABs (I suspect it does), but in that application, (1) the monoball allows full rotation to maintain suspension geometry, unlike poly, and (2) the NVH difference between poly and monoball is basically nil. Not sure I see the benefit of poly in this case if racing rules permit both types. |
07-26-2019, 01:46 PM | #17 | |
3085
Rep 2,747
9ers
Drifter2090909.50 |
07-27-2019, 08:40 AM | #18 | |
910
Rep 2,091
08-01-2019, 09:39 PM | #19 |
2181
Rep 1,664
I have the bimmerworld monoballs, they massively reduced steering shimmy under heavy braking on track. Took some of the initial 'gloopiness' out of the steering as well so it feels a touch more connected. No additional NVH I have detected.
08-05-2019, 05:58 PM | #21 |
87
Rep 400
08-06-2019, 05:41 PM | #22 | |
898
Rep 6,285
