10-28-2018, 11:24 PM | #1 |
142
Rep 379
Hi, I was changing my tires today and noticed that my rear passenger tire gap was lower than my rear driver side wheel gap. I can fit 2.5 fingers in the passenger gap and 5 fingers in the driver side wheel gap.
The oem wheel is the rear driver side |
10-29-2018, 12:39 AM | #2 |
2114
Rep 2,388
Usually ride height is determined by springs (unless you have adaptive suspension). Did you drive before you took the photos? The thing is that if you just lowered the car from jack stand and took photos - it will be uneven. It usually needs to be driven a bit (like even 10-20ft) to let springs/shocks settle down.
If you drove it and it's still that way - then you need to look further at tires and/or suspension. Give us more info: what kind of suspension you have, what tires and when you put them? |
Rox335i141.50 |
10-29-2018, 01:48 AM | #3 |
228
Rep 287
Drives: '22 X4 M40i / '24 X5 M60i
What DuSh said. It scared me the first time too.
You will be ok once you drive the car around the block. |
10-29-2018, 09:09 AM | #4 | |
142
Rep 379
10-29-2018, 07:21 PM | #5 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
My guess is you have rear air suspension. It gets a bit wonky when up on a jack and leaning back. Happened to me when I replaced the springs in the front. Had it on jack stands for a day and when I put everything back together my whole rear end was slammed. Ended up having to detach the rear links and turn the car on to force the pump to fill them with air again.
'07 Yamaha R1 (sold)
10-31-2018, 12:12 PM | #6 |
Mmmmm…
1151
Rep 2,426
Drives: F15
It sucks on the side of the road when you realize now you can’t get the jack from out under the car because the suspension has settled on the spare tire.
I usually lock the car, wait the 8 minutes for the electronics to turn off, then I unlock the car and the compressor lifts the rear back up.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
