10-21-2018, 01:24 PM | #1 |
///M SubDriver
1837
Rep 2,784
Drives: 2017 M3, 2020 X7 40i
S55 Engine Coolant Flush DIY?
So I have been following the Mike Miller "old school" preventative maintenance plan on my M3 ever since I got it and it is about time to replace my engine coolant in accordance with that plan (every two years - my car will be two in a month). I have seen the BMW factory procedure, which just has you disconnect the lower radiator hose. This will obviously drain the radiator and some of the engine block, but I suspect there will still be a decent amount of old coolant remaining in the system.
So my question is, has anyone ever completely drained and flushed the S55 engine coolant system? If so, any pointers (to include the location of an engine block plug if there is one)? Is it possible to use the two electric water pumps in the coolant system (the one for the turbos and the one for the heater core) to help flush as much coolant out of the system as possible (like possibly using the bleed procedure to turn on the electric pumps in the system or some other ISTA procedure to manually turn on the pumps)? I found some stuff on the N55 during my search, but while the S55 is based off of the N55, there are still plenty of differences that could make this process different enough for the S55. Thanks!
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
12-18-2018, 06:39 PM | #3 | |
79
Rep 98
02-23-2019, 01:28 PM | #4 |
Rep 69
Can't find any coolant flush interval recommendations from BMW. Even out to 120k miles.
https://www.bmwcharlottesville.com/s...esville-va.htm |
02-23-2019, 10:37 PM | #5 |
///M SubDriver
1837
Rep 2,784
This is about as close to any "official" guidance you will see....
https://www.newtis.info/tisv2/a/en/f...-check/1DUJMrq But even then it says that due to "technical progress" coolant replacement is not necessary beginning with gas powered vehicles produced after 3/2003.....
02-23-2019, 11:24 PM | #6 | |
Just Building My M4 Track Car
216
Rep 863
Drives: 15’ M4 Alpine
That’s what I like about new cars but this still gets me mad on my old Ferrari Last edited by Alpine_F82; 02-23-2019 at 11:31 PM.. |
02-28-2019, 06:24 PM | #7 |
125
Rep 212
For those of us who like to over-maintain
our cars (i.e., old-school), has anyone figured out a way to drain all the coolant ?
I read Dinan's instructions for changing out the radiator, which starts w/ removal of the hose near the bottom of the radiator on the passenger side, but I only managed to drain about 1/4 gallon of fluid. What is the trick for draining the entire system (which I believe is close to 2 gallons) ? (Thank you in advance for not telling me a coolant flush is unnecessary.) |
03-01-2019, 08:34 PM | #8 |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
I don't know what the "recommended" method is, but a few decades ago I used to do a drain and flush on my cars by pulling the lower radiator hose, sticking a garden hose into the upper radiator hose (before overflow tanks) and then just running the engine until everything came out clear. Then you stuck the hose into the upper radiator and flushed it until it was clear.
I suspect that's not the way it's done now...
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
03-02-2019, 10:45 AM | #9 | |
///M SubDriver
1837
Rep 2,784
I actually broke down and had the dealer do it when my car was in for routine maintenance. They have a machine that takes a suction on the cooling system to get the old coolant out and new coolant in, similar to the one in the video below... https://www.youtube.com/watch?v=LBYJ_9Q0m0w Since the coolant in my car is not "old & crusty" I am not worried about any of the residual coolant that may remain in the system after using this method since essentially all of the old coolant will be removed from the system. The dealer charged me ~$200 which was an easy sell for me - at least for now. When my next coolant flush will be due, which will be in 2 yrs, I will look deeper into doing it myself.
03-03-2019, 09:13 AM | #10 |
291
Rep 456
Sorry for hijacking this thread, but it's in the same ball park and I thought some of you could help.
One of the other UK Bimmerpost members mentioned yesterday that his coolant levels were low after picking up his M2 Comp so I checked my level also after picking up my M2 Comp on Friday and mine was also low, so I topped it up to recommended levels. I then later in the day drove about 10 miles to pick up a pizza and as I pulled in to the car park the engine was steaming. I looked under the bonnet and at that point I saw the coolant cap sitting in the engine bay where I left it as well as coolant spluttered all over that side of the engine. I know, I know, stupid mistake (I still can't believe I did this). I followed the trail of coolant and it looked like it only started leaking from the engine 150 feet away from where I parked my car. After picking up the pizza I put the cap back on, drove it home at the lowest revs possible and used a cloth to clean up all the coolant I could reach and then left the car to cool down. I have been reading that I should bleed the coolant system and I have seen some guides on this, but only for older BMWs. / M cars. Can you guys please advise me what I should do? If any one could show me a picture of where the bleed screw is explain what I need to do to bleed the system I would massively appreciate it. I have seen on the internet that I might have to turn the ignition on, put the heating on high, etc, etc, but a detailed response would help. I am taking my car 50 miles to get some parts added tomorrow so I'd love to get this sorted today. Would it be ok to simply top up the coolant, drive the car and get them to sort this out? I would rather do it myself today if I had the right guidance. I feel pretty dumb for making such a rookie error, but hey-ho, you learn from your mistakes and all that. Cheers, Karl
2019 HS DCT M2 Competition with Essex AP Racing Radical Pro5000r front and rear BBKs, Bilstein B16s and 763M wheels with Cup 2s
03-03-2019, 03:59 PM | #11 |
///M SubDriver
1837
Rep 2,784
There is no bleeding screw on the S55. You should be fine with just toping it up with distilled water. Running the bleeding procedure would not be a bad thing. The factory procedure is below....
https://www.newtis.info/tisv2/a/en/f...eck/1VnXqfU9E9
Sejo540.00 |
03-09-2019, 08:57 AM | #12 | |
37
Rep 180
Personally, I’d probably avoid puttingbtap water in just to prevent any minerals from staying in the system, although it would probably be minimal. |
