10-19-2018, 02:30 PM | #1 |
158
Rep 269
Drives: ///M6 GC
21s | offset | fitment | misc mods
KW HAS
https://trinityautosports.com/kw-h-a...5-type-m5-m6-1 Front: Lowest setting Rear: Alignment = even tire wear Front: 21x10 et26 = 1MM gap between rim & string 275|30|21 Rear: 21x11 et10 = 1MM gap between rim & string 305|25|21 Future setup: 21x10 et26 - 275|30|21 21x12 et22 - 325|25|21 https://www.willtheyfit.com/ How to install: Last edited by BadSeed; 08-19-2020 at 08:37 PM.. |
10-19-2018, 02:47 PM | #2 |
158
Rep 269
Drives: ///M6 GC
LED bulbs. No errors
Replaced all dome lights, both footwell, glovebox, doors & trunk. 13 LEDs total T10 (W5W) 5730 8SMD 1. https://www.ebay.com/itm/20x-Brand-T...4AAOSw-NFavKs4 2. https://www.ebay.com/itm/20PCS-Super...sAAOSw3Jxcut02 3. https://www.ebay.com/itm/20pcs-set-5...IAAOSwOntfKYGG T10 (W5W) 3014 24SMD 1. https://www.ebay.com/itm/10x-194-W5W....c100005.m1851 2. https://www.ebay.com/itm/10x194-W5W-...8AAOSw-3NfOSb1 3. https://www.ebay.com/itm/10pcs-Set-1...MAAOSwobJfUCHB T10 (W5W) 3014 24SMD These will probably be the brightest for dome lights https://www.ebay.com/itm/Error-Free-...53.m1438.l2649 T15 (921) 3030 10SMD reverse light bulbs No errors https://www.ebay.com/itm/2x-3030smd-...53.m1438.l2649 How to install: Last edited by BadSeed; 09-06-2020 at 09:01 AM.. |
Flying Ace4984.50 Junebug851616.00 |
10-19-2018, 03:04 PM | #4 |
158
Rep 269
Drives: ///M6 GC
Took 9 resets & drove nearly 20 miles but it eventually registered.
I purchased this exact set & used on the aftermarket rims. Black valve stem TPMS https://www.ebay.com/itm/TPMS-Sensor...53.m1438.l2649 Note: This (RDE017) only works on vehicles w/ a production date after 3/1/2014 My OEMs. Installed these black valve stems https://www.ebay.com/itm/New-Black-C...IAAOSwTuJYpjbJ https://www.prismaticpowders.com/sho...coating-colors - Use Chrome, Edge or Firefox. IE11 not supported Prismatic Powder Evo Gray color powder coat. $300 - 2 day turn around time Last edited by BadSeed; 04-21-2020 at 09:54 PM.. |
10-19-2018, 03:05 PM | #5 |
158
Rep 269
Drives: ///M6 GC
275|30|21
305|25|21 Last edited by BadSeed; 12-23-2019 at 08:08 AM.. |
10-23-2018, 01:54 PM | #7 |
158
Rep 269
Drives: ///M6 GC
You missed it on the 1st post
Rear: 21x11 et10 305|25|21 Last edited by BadSeed; 12-23-2019 at 08:09 AM.. |
10-23-2018, 06:40 PM | #9 | |
158
Rep 269
Drives: ///M6 GC
Light rubbing on all tires, just enough to remove tire gel. Its not really digging into the tires. |
Flying Ace4984.50 |
10-23-2018, 06:51 PM | #10 |
158
Rep 269
Drives: ///M6 GC
Couple more mods.
AutoTecknic Competition Steering Shift Paddles 1. https://trinityautosports.com/autote...-x5m-f86-x6m-1 2. https://ind-distribution.com/collect...ift-paddle-set Squeak went away over time Pedal Haus aluminum pedals http://www.pedalhaus.com/f12.html Last edited by BadSeed; 06-28-2020 at 07:30 AM.. |
10-24-2018, 07:52 AM | #12 |
158
Rep 269
Drives: ///M6 GC
10-24-2018, 09:09 AM | #13 | ||
17
Rep 51
10-24-2018, 02:32 PM | #14 |
158
Rep 269
Drives: ///M6 GC
ts-m516.50 |
10-24-2018, 02:50 PM | #15 |
158
Rep 269
Drives: ///M6 GC
All weather floor mats though unnecessary where I live
1. https://www.ebay.com/itm/For-BMW-Mos...9mwlj8le9yisOw 2. https://www.ebay.com/itm/Custom-Car-...ohVeVcAsBZHTiA Last edited by BadSeed; 12-20-2019 at 11:11 AM.. |
10-28-2018, 02:42 PM | #18 |
158
Rep 269
Drives: ///M6 GC
Front spoiler: Purchased from these sellers
1. https://www.ebay.com/itm/Auto-Front-...53.m2749.l2649 2. https://www.ebay.com/itm/26506643405...53.m1438.l2649 Other sellers: https://www.ebay.com/itm/26506643405...MAAOSwB5tgNti4 https://www.ebay.com/itm/28431205262....c101113.m2108 https://www.ebay.com/itm/18303774933...YAAOSwL1VfI1x~ Non CF version: https://www.ebay.com/itm/19415937725....c100903.m5276 https://www.ebay.com/itm/28430774471...pid=3047184953 Fitment: - Took 11 screws to remove gaps so it looks somewhat decent Looks: - Aggressive Clearance: - reduced to 4" (KW HAS lowest setting) Gran Coupe side extensions: Purchased from this seller, US stock received in 3 days. https://www.ebay.com/itm/V-Style-Car...53.m2749.l2649 Another seller: Gran Coupe side extensions https://trinityautosports.com/bmw-f0...irt-extensions Fitment: - required cutting to clear the jack pads - Took 4 screws & double sided tape to look somewhat decent - length is about 1MM too short but close enough Looks: - Fairly aggressive Clearance: - 3.5" front jack pad (KW HAS lowest setting) - 4" rear jack pad Last edited by BadSeed; 06-17-2021 at 11:01 AM.. |
10-28-2018, 02:44 PM | #19 |
158
Rep 269
Drives: ///M6 GC
11-02-2018, 02:03 AM | #20 |
4985
Rep 11,891
looking forward to interior LED pics
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
11-02-2018, 07:44 PM | #21 | |
158
Rep 269
Drives: ///M6 GC
13 LEDs are from this T10 W5W 6000K LED https://www.6post.com/forums/showpos...85&postcount=2 1 - driver footwell 1 - passenger footwell 1 - glovebox 4 - door 3 - front roof dome lights 2 - rear roof dome lights 1 - trunk luggage How to install: https://www.newtis.info/tisv2/a/en/f...hting/Bz92M5V8 Trunk lid LED 42MM festoon https://www.ebay.com/itm/2XPure-Whit...53.m2749.l2649 How to install: https://www.newtis.info/tisv2/a/en/f...hting/1LasgwdU 3 months of ownership & didn't know the door sills light up until today. Last edited by BadSeed; 08-19-2020 at 08:36 PM.. |
