09-26-2018, 09:10 PM | #1 |
46
Rep 450
Airlift Install... HELP!
So i'm installing my airlift setup and im down to a couple of things.
First, what fuse does everyone tap into for the signal wire? I put it to the fuel pump fuse to see if everything was working because we want a fuse that's hot when cranking and while running/on but it turns out the fuel pump is always hot on these cars after seeing with a test light. The compressor kept running after shutting everything off though so we don't want that because that will kill my battery. Second, my 3p app didn't want to pair. I read online to do the 3 seconds on 3 seconds off and then back on to put it in pairing mode but when i had the app up, it just asked to attempt pairing and i clicked it and then it said the manifold wasnt in pairing mode even after I did the pairing sequence. Should I need to go to my iphone settings to check for the bluetooth connection and connect there first or what am I doing wrong?? Also if anyone has an extra controller for a 3p airlift setup, i'd be glad to buy it off of you. 360 628 6006 shoot me a text. Any input helps. If you could, show the whole pairing sequence on a video and text it to me, that would be ideal. Thanks! |
09-28-2018, 09:11 AM | #2 |
F15 daddymobile
2350
Rep 3,510
Have you called airlift? They have excellent customer service. I'm sure someone there can walk you thru the process
09-28-2018, 12:55 PM | #3 |
I got lei'd
844
Rep 7,593
Are you running single or dual compressors?
After step 9 "car will start moving..are you ready?"...does it say calibration failed? if it does and your manifold/ECU/brain of the airlift is mounted any other way except flat on its back, take it off and lay it on its back...let it calibrate and say baseline and once you're done getting your preset ride height settings mount it back up the way you want it. After all that, you should be able to pair your 3p app to your phone. Which remote do you have? I have the buttons to the right, screen to the left. I want the one with the screen on top, buttons on the bottom. If you want to trade for mine LMK. |
09-28-2018, 11:03 PM | #4 | |
46
Rep 450
and i have a single compressor |
09-28-2018, 11:08 PM | #5 | |
I got lei'd
844
Rep 7,593
09-29-2018, 12:23 AM | #6 |
46
Rep 450
do you have a link?? maybe im being duped and i may take you up on the compressor, let me see how my compressor works once its set on the ground tomorrow
09-29-2018, 09:52 AM | #7 | |
I got lei'd
844
Rep 7,593
No worries, having 2 compressors now makes a world of difference in filling up like 2 psi every second instead of 1 psi every 3-4 seconds. |
Tags |
air, airlift, bags, bluetooth, install, lift |
