09-16-2018, 01:43 AM | #1 |
Rep 4
KW Clubsport usable on E93?
KW websites says KW Clubsport is available on E90/E92. Can I use it for my E93? Wondering because for KW V3 there is E93 specific one.
09-16-2018, 11:02 AM | #2 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
It will fit but they probably use a higher spring rate in the rear of the e93 version of the V3 to compensate for the added weight of convertible. The clubsport is a more track oriented kit. KW probably assumed the market is small for those tracking an e93. You could get a stiffer rear spring but the shock valving might not be well matched.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
09-16-2018, 03:01 PM | #3 | |
Rep 4
