09-12-2018, 04:09 PM | #1 |
244
Rep 433
Ground Control STREET camber plates + fitting 295/30 tires on the front.
Can anyone confirm if the bump stop washer/cap needs to be installed with the GC Street plates? Seems like my car sits 1/4" higher after the plate install, and I was told ride height wouldn't change.
09-12-2018, 10:30 PM | #2 | |
4100
Rep 1,612
That washer wouldn't change the ride height anyways unless your ridding unnecessary on the bump stops, if that's the case you have bigger problems to worry about lol. But anyways, take it all back apart, you forgot to put the rubber top mount around the spring on top bud, that's gonna make horrific noise |
09-13-2018, 01:45 PM | #5 | ||
244
Rep 433
yes. Quote:
Also, fyi, GC can provide what they call a short version of this plate which allowes increased suspension travel for those with lowering springs. I believe you need to call them to order these, otherwise you get the standard version which maintains the same travel as OEM. |
09-13-2018, 02:27 PM | #6 | |||
4100
Rep 1,612
Nearly flat I've done so many set at the shop and I can slightly remember the differences Just go clubsports and not worry about any of this Jk jk |
09-16-2018, 12:20 PM | #7 | |
244
Rep 433
For my current needs and I am very much enjoying the ZCP suspension. I'm only adding camber plates and potentially a large/adjustable front sway. BTW, per Donavan from GC their street plates are designed to not need the top spring pad. |
09-26-2018, 04:37 PM | #8 |
244
Rep 433
Final update on these, for anyone planning to run the GC STREET camber plates on a ZCP M3 (or with lowering springs)
1. Make sure to order the "short" bushing version of the GC STREET plates, you'll likely need to call and specifically request this. Otherwise, as was in my case, the car was resting on the bump stops, which isn't ideal and furthermore raised the car a bit. 2. I would also recommend swapping to the shorter E36 bump stops as they allow for a little more suspension travel. 3. I chose to use the bump stop cap/washer as it engages the entire bump stop rather then just the small inner portion of it as would the metal sleeve which comes with the GC plates. 4. Per GC I did not use the top spring pad and have not noticed any additional NVH. *In the end the car sits about 2mm higher. **Pics of the shorter bushings. |
CSBM52722.50 |
10-08-2018, 09:19 AM | #9 |
244
Rep 433
Max camber these plates allow, for track days. Still happy with the plates; they are working very well for my needs.
StripclubDJ4100.00 |
10-08-2018, 11:17 AM | #10 |
4100
Rep 1,612
10-08-2018, 12:20 PM | #11 | |
244
Rep 433
Looking at the second photo makes me believe I could run a much wider wheel and tire. Just for fun I may install one of my 11" rears with a 295/30/18 tire on the front. |
10-08-2018, 12:23 PM | #12 |
4100
Rep 1,612
This is mine
-3.5 r -2.0 r 18x10 275 +25 15mm spacer 18x11 305 +44 15mm spacer |
M3ANMACHINE931.00 |
10-08-2018, 04:53 PM | #14 |
4100
Rep 1,612
10-08-2018, 04:56 PM | #15 |
244
Rep 433
10-08-2018, 05:32 PM | #16 | |
4100
Rep 1,612
I got the 2 front for free so I figured I'll give them a try So far on the canyon sprint I did it was too much grip for me to test on the street ofcourse lol I just wanna see how the side wall stiffness is really, ofcourse the nt01 is a superior tire, but hey why not give it a try and see what happens And thanks man! |
10-08-2018, 05:35 PM | #17 |
4100
Rep 1,612
Fitment came out pretty decent and zero rubbing, you should throw some spacers on with the camber you have now
How does your car handle now with the plates ? |
10-08-2018, 06:41 PM | #18 | |
244
Rep 433
I'm tempted to try a 11" front and 12" rear... but not sure who makes wheels in those sizes with the correct offsets. |
10-08-2018, 07:21 PM | #19 | ||
4100
Rep 1,612
The 11 is a couple mil from the inside body on the rear And a 11 front lock to lock just won't work We've tried 10.5 lock to lock required a fuck ton of shaving the pinch weld on the race car, all the way to the flat body and still rubs |
10-08-2018, 07:37 PM | #20 | |||
244
Rep 433
10-08-2018, 08:03 PM | #21 | ||||
4100
Rep 1,612
Most I would do is 10.5 You really aren't gaining anything with a 11/12 |
10-25-2018, 03:53 PM | #22 |
244
Rep 433
Just for fun, I decided to test fit my Apex EC7 18x11 et44 (rear) wheels with 295/30/18 Advan A052 tires on the front of my car.
I have GC street camber plates installed and for the purpose of this testing, I had them set to max camber. I also have HR springs installed on my '13 ZCP e92. First I tried a 20mm spacer for an effective offset of et24. This was a no go and the wheel touched the strut. Shown in photos: #1, #2. Next I tried a 25mm spacer, which cleared the strut just fine, for an effective offset of et19. (et20 should work as well, so the common 18x11 et25 wheels with a 5mm spacer would be ideal, imo) Photos: #3->#9 show this fitment. Photo #8 shows the clearance to the front of the liner at full lock, and photo #9 show the slight rub on the back of liner again at full lock. Conclusion, I believe running a 295/30/18 tire on a 18x11 et20 wheel is do-able with a track only alignment (max negative camber). . Last edited by Adrian g.; 10-25-2018 at 04:22 PM.. |
